My car is a 1966 300HP Base Engine. Here is my problem>
I will adhere the decals and they will be fine at first. After a while they curl off. I could use some suggestions to
keep them from doing this. I have the adhesive(Peel Off The Back) type. I have never seen these offered in the
"Water Soluble" type. What is the current thinking on this problem?
Does anybody know of a "Heat Resistant Adhesive" to put under the corners? I am reluctant to use "Super Glue";
but would try it IF IT WORKS.
Has anybody tried this? Results? Need Comments>Larry
