Thermostat issue? - NCRS Discussion Boards
Thermostat issue?
  • Gary A.
    • May 31, 2001
    • 165
    Thermostat issue?
    I've had a productive winter with my 67. I re-installed the missing power brake booster, removed the aftermarket side exhaust and replaced with original exhaust manifolds and returned the car to original under car exhaust. I removed a electric fuel pump with associated rubber lines, and returned the car to original fuel line and mechanical pump. Lastly, installed a 3885069 intake to replace the leaky, cracked aftermarket that came with the car. Well, fired it today. Runs good but I think I might have a stuck T-Stat. the lower radiator hose, heater hoses, by pass hoses hot to the touch. Upper radiator hose and radiator, cool to the touch. Stuck thermostat??. Gary
  • Leif A.
    • August 31, 1997
    • 3658
    Re: Thermostat issue?
    Sure sounds like it. Hopefully, that's it...easy fix. Sounds like you had a very productive winter.
    Leif
    • Gary A.
      • May 31, 2001
      • 165
      • Anthony C.
        • March 21, 2022
        • 207
        hi gary I had a similar problem with my 75 and i replaced it with a180 which my owners manual calls for . still the upper hoses was running cool 160-165 Ithan replaced it with a 195 and that solved the problem.
        • Keith M.
          • January 17, 2021
          • 695
          Maybe I just do not.understand thermostats..but if one goes from.180 to 195 thermostat stays closed longer and so how does that fix cooler hose issue??
          late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
          • Gary C.
            Administrator
            • October 1, 1982
            • 17971
            Gary,
            Best thermostat for our Corvettes are Robert Shaw. Why, they don't stick closed.
            There are a couple of racing supplies that have Robert Shaw thermostats with bleed holes drilled in them that makes it easier to remove trapped air.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
              • 43290
              Anthony-------
              I'm VERY surprised that your 75 owner's manual specifies a 180 degree thermostat. All 1975 Corvettes were equipped with the Air Injection Reactor (AIR) emission control system. In all cases that I'm aware of, GM vehicles with AIR are equipped with a 195 degree thermostat. Non AIR equipped vehicles of the period usually spec a 180 degree thermostat.
              However, I recommend a 180 degree thermostat for all 1963-1980 Corvettes, with or without AIR.
              Also, I do not understand how the installation of a 195 degree thermostat could, in and of itself, correct the problem you describe when using the 180 degree thermostat unless that thermostat was defective.
