Re-use proportioning valve? - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    Would like some input on whether or not to re-use what I believe is the original proportioning valve from my car...see pix. My restore philosophy is to keep original parts unless either 1) they are so hideous that they significantly detract from the car, and/or 2) there could likely be or would be performance issues. In this case the valve is by no means pretty...but it's location is not in a place where that would bother me and I would prioritize keeping this original part....UNLESS I am potentially creating a likely leak problem that would require me to drain the brakes and then replace it anyway. Thoughts? And I guess same goes for the small brass blocks in the rear. If there is a reasonable chance they will perform ok then I prefer to keep. OTOH it IS the brake system so I need to keep that in mind. And re-using does save me the $90 or so for another one. I am NOT chasing awards so that is not a factor and please no comments about points this or that or awards.
    If you feel it wise to replace, who makes the best repro? My sense is all the usual retail places are sourcing from the same place...or two...but who makes the best.
    TIA
    Keith
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Ron G.
    • December 1, 1984
    • 866
    Re: Re-use proportioning valve?
    Keith,
    There is a company called Lone Star located in Texas. They specialize in rebuilding and remanufacturing brake part components. I had my original brake proportioning valve and power steering valve rebuilt by them. They did an excellent job and they made sure that I got my original parts back. The person that answers the phone will tell you to just send them in, but my recommendation is to ask to speak with Brad Lindsey. Brad will oversee and expedite the rebuild of your parts. Their reach number is: (903) 829 - 8400. If you do decide to use them, reference my name to Brad. - Ron
    "SOLID LIFTERS MATTER"
    • Keith M.
      • January 17, 2021
      • 695
      Originally posted by Ron Goduti (8076)
      Keith,
      Thanks Ron!! That's great to know. I was not aware they did that service. I got my rebuilt correct brake calipers and master cylinder from them last year. And as it turns out steering control valve is just about out and I had them targeted for the rebuild. I can ask when I call but wondering if you are aware of any other services they are best for??
      • Leif A.
        • August 31, 1997
        • 3650
        Keith,
        The item you refer to as a "proportioning valve" is actually called a Brake Distribution Switch & Metering Block Valve. It's job is to detect if one or the other of the master cylinder bowls is low/empty of brake fluid. The switch would then turn on your "brake" light on your dash to alert you.
        Yours appears to be in serviceable condition...I would reuse it.
        BTW, there was a proportioning valve used when J56 special heavy duty brakes were ordered.
        Leif
          • 15706
          Any kind of leak on one side causing that side to loose pressure will move the switch and light the "brake" light in the IP.
          Many cars of the era, especially those with disk/drum systems use what GM calls a "combination valve" that provided the differential pressure sensing with rear pressure proportioning.
          Soak the valve in denatured alcohol for a day and then thoroughly dry, and it should be okay to use. You can probably use air pressure and an ohmmeter to verify that the switch functions.
          • Keith M.
            • January 17, 2021
            • 695
            Thanks all. Consensus seems re-use...with some cleaning/prep first. Can I assume this applies to the smaller blocks in the rear....meaning good to re-use?
              • 15706
              The tee in the rear brake pipe just distributes pressure to both rear calipers - no moving parts, so okay to reuse if clean.
              • Jeffrey S.
                • May 31, 1988
                • 1898
                Keith,
                Definitely keep your original. Yours appears to be dated the 273rd day of '69 (stamped into side). It is not hard to "liven" up the brass with Brasso or some other brass polish (Simichrome Polish, etc.) Be aware that the size of the line fittings on a '69 block are different than '70 and up. I don't have the sizes here but I do have several of both and they are not the same. If you send off yours for rebuilding be sure that they send the same one back to you.
                Jeff
                • Keith M.
                  • January 17, 2021
                  • 695
                  Originally posted by Jeffrey Salz (13182)
                  Keith,
                  Jeff
                  Hi Jeff,
                  Holy smokes. I did see that stamped number but had no idea of stampings on these....ie. did not know of part # stamps nor date codes. If that is indeed a 1969 day...then it was Sept 30 which is ideal match up with my late Oct built car. Dunno what Lonestar charges but it probably worthwhile to get it looking purty and more importantly ensuring solid functionality.
                  Thanks so much,
                  Keith
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11362
                    Here is a 1967 version. There is a small spool inside which moves when there is a differential in fluid pressures. It makes contact to the switch pin when activated.
                    This is what most look like..
                    Disassembly...
                    The only way to clean the internal spool is to remove it. The o-rings should be replaced also. Sizes below. Remove the brass insert on one end and push the spool out the other end. To remove the insert, Screw-Tap the center of the insert and make a puller from a old fitting and mating thread screw/washers. New inserts are available from some of the vendors.
                    Here's a folder of photos for reference, along with some notes.
                    Assembly. The new brass inserts are installed using a appropriately sized fitting and simply pressed in until they bottom out. Originals can be reused provided they're not externally damaged.
                    P1170001.jpgP1170002.jpgP1170003.jpgP1170006.jpgP1170007.jpgP1170008.jpgP1170011.jpgP1170022.jpgP1170023.jpgP1170025.jpg
                    • Leif A.
                      • August 31, 1997
                      • 3650
                      Rich,
                      Your tutorials are masterful!!
                      Leif
                      • Owen L.
                        • September 30, 1991
                        • 891
                        Originally posted by Leif Anderson (29632)
                        Rich,
                        I'll second that - so helpful on how the components look and how they're assembled.
                        Does the switch pin just pull out once the nut is removed?
                        • Keith M.
                          • January 17, 2021
                          • 695
                          Yeah...now that I know there is so much going on in there will definitely have Lonestar do a rebuild/restore.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11362
                            Rich,
                            Thanks Gents.
                            On that one in my first post, after the threaded sleeve is removed the contactor just pulls out. This was from a March car.
                            I've done a few over the years. Some have differently configured pin switches. I'm unsure if these differences were due to different GM vendors making them or if the suppliers changed their designs over time. I suspect the latter.
                            Here is another type from a early '67(Nov built). As you'll see the switch is a different configuration.
                            The contactor on this type screws into the threaded housing. Note the insulator sleeve around the slotted screw head.
                            Center of the spool inside the case.
                            Note the recess in the housing, made to fit the switch assembly o-ring to seal any escaping fluid if the spool seals leak.
                            Of course the caveat is I don't truly know if these two I showed were definitely originals, but I suspect so.
                            Rich
                            • Keith M.
                              • January 17, 2021
                              • 695
                              Do these things not have a "failsafe" built in? Or is that just with a true proportioning valve...or do those not either? What I mean is...I thought there were some devices that worked such that if the front or rear dropped pressure the light would kick on but the valve would ensure the "good" side ...front or back still functioned.
