Re-use proportioning valve? - NCRS Discussion Boards
+ More Options
Posts
  • Owen L.
    • September 30, 1991
    • 882
    Re: Re-use proportioning valve?
    The O-rings on the master cylinder's pistons and on the shuttle in this switch/distribution block keep the two circuits in these common components separate enough that either the front or back should still function as intended if the other loses pressure.
