63 fuelie distributor "tinny squeal" noise - NCRS Discussion Boards
  • Monte K.
    • October 16, 2022
    • 5
    Hello,
    I am a new member to NCRS.
    History: I currently own what was my Grandfathers (Russ Cook) '63 fuelie coupe. He restored the car in '84. He left it to me in '05 after he passed. About 2 years ago the car began running pretty cruddy. Hesitating on acceleration, surging at a constant rpm, vapor locking during hot starts. After talking with a few enthusiasts, I decided to try running AV gas. This helped quite a bit and ran a bit smoother, but still had most symptoms although the vapor lock stopped. About a year ago, it developed a severe fuel leak out of the bottom of the fuel meter. Likely from years of old ethanol gas use and sitting for long periods of time. This forced me to do a rebuild of the FI, which I was dreading but knew that time would come. With some great advice and wisdom from a gentleman in Pennsylvania, and getting my 16 year old son off the computer, we made it a father son project. We also performed a valve adjustment.
    It went fairly smooth and the car fired right up. Running better than it ever had since I owned it!
    Currently its still running pretty good. It still has what I refer to as surging. While at a constant throttle and no load, the rpm fluctuates up and down. Running smoother at the higher point and rougher at the lower point. When I accelerate it really runs smooth at about 3,000 rpm and up. Could this be a detonating/timing problem?
    The other issue that very recently came up and is more concerning to me is a tinny squeal that seems to be coming from the top end of the distributor. Very noticeable at idle, but hard to pinpoint. I have disconnected the tack cable and it still exists. I checked and greased the FI pump drive cable as well. Mt next thought is to pull the distributor to check the gears at the bottom half.
    Does anyone out there have any similar experiences with either of these issues? Any advice is well appreciated!
    Also, does anyone know of any trusted, experienced mechanics in the Seattle area that you would trust and might help with diagnosing these issues?? Oh, I also have a video of this sound. Attaching and sending it in this thread might take me some time though!
    Thanks for your time!
    Monte Koch
  • Don H.
    • December 1, 1981
    • 1491
    Re: 63 fuelie distributor "tinny squeal" noise
    If you want to have the distributor rebuilt, Don Baker (815-210-3057) is the VERY BEST! Good luck, Don H.
    • Monte K.
      • October 16, 2022
      • 5
      Thank you!
      • John S.
        • June 15, 2015
        • 506
        1973 L82 M21 4 Speed, very original and well documented driver/survivor
        NW Chapter Member, 2016 Bend Regional Top Flight
        73/74 TIM&JG 3rd Edition Revision Team Member
        • Michael V.
          • May 31, 1995
          • 77
          Monte,
          I just sent you a private message with Larry Webb's contact information along with mine. Thanks, Mike
          • Danny P.
            • June 30, 2002
            • 344
            Originally posted by Monte Koch (69750)
            Hello,
            Monte Koch
            Monte, check the oil line fitting behind intake to see if oil is getting to the distributor fitting could be plugged at the fitting or a bearing/bushing worn out.
            • Monte K.
              • October 16, 2022
              • 5
              Hi Danny,
              I just replaced the oil feeder line and fittings. Also checked the cross shaft and gears. All looked in good condition. I know oil is getting to the distributor because when I ran it after replacing the parts, I had a small leak at the fitting entering the shaft so I cinched down the nut a bit.
              Thanks for the feedback!
              • Danny P.
                • June 30, 2002
                • 344
                That’s Good as long your getting oil to the Dist. Hard to tell without hearing it , best bet pull the dist. And go through the bushing and bearing maybe something in the shaft that wearing out .
