Greasy oily mess under hood - NCRS Discussion Boards
  • Mark H.
    • November 1, 1976
    • 120
    Starting to get the '66 coupe (L79) ready for spring when Wisconsin's weather allows. Noticed a greasy oily coating that the fan apparently blew around and coated a good bit under the hood. I have cleaned it up just fine. What do you suppose is the cause? Any ideas of what I should check would be appreciated. Thanks.
  • Kent S.
    • February 1, 1993
    • 203
    Re: Greasy oily mess under hood
    Check the fan clutch - they have been known to leak.
    • Mike M.
      • May 31, 1974
      • 8383
      if C60 equipped, chef A/C compressor. mike
      • Mark E.
        • April 1, 1993
        • 4542
        Front timing cover, front seal, intake manifold seal, power steering lines or pump are other things to check. Can you tell the type of fluid?
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
