How will this be judged? - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7024
    Re: How will this be judged?
    Originally posted by Tony Stein (4600)
    The F41 components on an L36 car will receive a FULL DEDUCTION. This is not governed by CDCIF. Please refer to section 9 of the Standard Deduction chart entitled, "Added or Deleted Options". Hope this helps.
    Tony
    Tony,
    Wow. I didn’t expect that answer. Just to cement this in my mind, as another example, if a car has an F41 front sway bar, but was born with and has standard suspension components for everything else, it’s a full deduct for front and rear suspension?
    Gary
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 988
      Gary. If the car was born with standard suspension, but it has an F41 front sway bar, then the owner would receive a full deduction for the front sway bar. Each suspension component is independently evaluated.
      Hope that helps.
      Tony
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
      • Donald H.
        • November 2, 2009
        • 2580
        #18
        Tony, not to beat a dead horse, but I assume you are saying the car will get an 8 point deduct for just the front springs and not 140 points for the whole suspension.
        Thanks again,
        Don
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • Tony S.
          • April 30, 1981
          • 988
          #19
          Good morning, Don. Remember, we independently evaluate each line item. So if your friend's L36 car has F41 springs, and no other F41 features, then only the F41 springs would be subject to the standard deduction.
          Judges seem more in tune with CDCIF, so naturally they evaluate based on CDCIF analysis. That is understandable. A less experienced chassis judge could make a call based on CDCIF. However, F41 was a production option, so it is subject to item 9 on the standard deduction chart.
          I hope this helps!
          Best regards,
          Tony
            • 11644
            #20
            How does one differentiate standard vs. F-41 front springs once they are installed in the car and the car is sitting on the ground in judging position?
            Rear springs, sway bar, etc, are easy.
            Thanks again,
            Don
            We still don't know how the judge can even tell it's not a standard spring.
            My thought is that it's quite difficult, and won't be noticed.
            • Tony S.
              • April 30, 1981
              • 988
              #21
              Patrick. Actually, the F41 spring has a much wider coil spread pattern than a standard spring. Come by the C2s some time and I'll be happy to show you.
              Best regards, Tony
              • Gary B.
                • February 1, 1997
                • 7024
                #22
                • Tony S.
                  • April 30, 1981
                  • 988
                  #23
                  Gary, you always bring much to the discussion. As always, thanks to you and all the others for your input. You and our contributors are why this is the best Corvette organization in the world. We create content. Tony
                    • 11644
                    #24
                    Best regards, Tony
                    That's what I was looking for - both for me and for others reading this thread.
                    I haven't judged Chassis much in the last decade unless the car is on a lift. My vertigo doesn't appreciate me laying on the floor with my head tilted.
                    • Tony S.
                      • April 30, 1981
                      • 988
                      #25
                      You have vertigo too? It is miserable. I can't lay flat on my back and look straight up.
                      Thanks for your posts! They are always welcome!
                      • Hank D.
                        • January 1, 1999
                        • 137
                        #26
                        • Standard Front Spring is GM part # 3851100 with a .600 diameter.
                        • RPO F40 / F41 Front Spring is GM part # 3832518 a .680 diameter.
                        When considering the Judging Guidance with respect to ALL components of F40 / F41 must match
