Dual brake master cylinder install - NCRS Discussion Boards
  • Wally A.
    • May 31, 1979
    • 170
    Wanting to install 67 style duel master cyl. on my 65 Corvette. Of course first on the list was to order a complete<br>kit thru Topflight corvette parts. During my attempt to install the new rear 1/4 inch line as per instructions, came<br>across the problem of the spiral wrapped line impossible to place as instructed. Of course i have come to a standstill.<br>I myself see that it is virtually impossible to install without lifting the body off the frame.. am i missing something<br>that i can't see? Absolutely not enough room to pass between the floor pan and # 3 crossmember.
    • 11659
    Re: Dual brake master cylinder install
    Wally,
    On the 63 here in the shop I removed the rocker panel and slid it in from the side. It was not horribly difficult, but it helped to have 2 people, with me under the car (on a lift) and my friend threading the line from the outside. We slid it in from ahead of the rear tire.
    There is not enough room to slide it in from underneath.
    • Wally A.
      • May 31, 1979
      • 170
      [QUOTE=Patrick Hulst (16386);926648]Wally,
      Patrick, thanks for the input, the kit i ordered comes with a 2 pc. line that runs front to back, was not sure of the
      access room to place it where the current line is running because of the bird cage over the frame rail . thanks again
        • 11659
        Our kit had the same 2 pieces.
        It should work.
