1957 radiator cap - NCRS Discussion Boards
1957 radiator cap
  • Kent S.
    • February 1, 1993
    • 205
    1957 radiator cap
    My correct (according to the JM) 7# cap is leaking. In talking to some fellow members in our chapter, they asked if it was a passenger car cap since there is a difference in the height of the gasket to cap (Corvette taller). Is this true or is my cap just defective? Thanks.
  • David B.
    • March 1, 1980
    • 689
    Re: 1957 radiator cap
    Never heard that one before, but today anything is possible. 1957 P&A Grp. 1.202 list 850795 RC-1 as correct cap for 54-57 Pass & 55-57 Corv.
    • Joe M.
      • April 30, 1990
      • 1338
      There is a difference. I purchased a Corvette cap for my 1960 off of ebay. It looked correct, but would not fit my car. The Vette cap has a longer neck than passenger car.
      • Kent S.
        • February 1, 1993
        • 205
        That's what seems to be the case with my cap. When I install it there is little if any downward pressure required as I turn to lock it in place.
        • David B.
          • March 1, 1980
          • 689
          Hard to say why you are encountering this problem. After 60 plus years obviously something has changed either the copper radiator or the off shore cap. If possible I would suggest you read Dr. Ed Gurdjian's well researched (as always) article in Volume 5 #4 on radiator caps from 1956 through 1965. From that article GM Assembly preferred Eaton cap 3708173 from 1956 through 1960.
          • David L.
            • July 31, 1980
            • 3310
            My 1957 Chevrolet Parts Catalog (Mar. 1957) lists GM # 850795 (RC-1, 7#) as the radiator cap for the following:
            54-57 PASS.
            55-57 CORV. 8 cyl.
            55-57 COMM., UTIL.
            I have a NORS 850795 (RC 1, 7#) cap in an AC box dated June 1988 but the cap has the "small ears" that measure 1.0" thick.
            I also have a NOS GM # 850797 RC-3, 7# cap in a very old AC box with the "large ear" that is stamped "TURN TIGHT", "REMOVE SLOWLY" , "AC", "MADE IN USA", "PATD." and "13" over "7#" that measures 1.25" thick.
            I also have a NOS GM # 861123 RC-18, 10# cap in a very old AC box with the "large ear" that is stamped "TURN TIGHT", "REMOVE SLOWLY" , "AC", "MADE IN USA", "PATD.", "RC-18" and "10#" that measures 1.0" thick.
            Dave
