Soaking Degreaser Recommendation? - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 688
    Re: Soaking Degreaser Recommendation?
    Originally posted by John DeGregory (2855)
    Jimmy Greg's idea is excellent. Now you will know one of my secrets. My helper and I learned many years ago that the dollar store Awesome is outstanding. Dirt cheap. It helps clean off the caked up grease on abused and neglected old fuel injections. I use it around the house also.
    Kersone is $7.00 a gallon in PA now. But my helper still uses it also.
    John D.
    Dirt cheap is the nice part. I have over $350 in Evaporust lately...i know different purpose...and great stuff...but...cha ching. Thanks for the intel.
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
    • Richard K.
      • April 1, 1988
      • 207
      I've cleaned a few things at the quarter car wash lol ! Worked well.
      If your control valve is the original one, KEEP IT. Pay the core charge if you want to replace it, AND ask if they balance them. SSBC used to balance then, but they have changed hands. They may also have original, rebuilt ones. The new ones aren't quite the same.
      I would rebuild an original one. It's fairly easy.
      • Keith M.
        • January 17, 2021
        • 688
        #18
        How would one determine originality?
        • Ed S.
          • August 6, 2014
          • 1377
          #19
          Just a word of caution - if you use any petroleum based fluids (kerosene) or other volatile liquid agents,......turpentine, acetone, alcohol, etc to clean car parts .... be sure you DO NOT put rags or paper towels that are saturated with the fluids in a trash can. If you do you will very likely be woken up by a member of the local fire departmental driving an axe through your front door in an attempt to rescue you.
          Any of those petrol based or volatile fluids will spontaneously ignite in a partially enclosed container. You need to have a plastic bucket filled about half way with water - immerse the saturated rag or paper towel in the water - once soaked it can be rung out and then spread out to dry - then when it is dry you can safely throw it in a trash can.
          Ed
          • Chris H.
            • April 1, 2000
            • 837
            #20
            Surprised no one has mentioned WD-40, a plastic brush or scraper, followed up with simple green. Has always worked for even the heaviest gunk.
            • Anthony C.
              • March 21, 2022
              • 207
              #21
              I used Citrus degreaser works great . Smells like orange
