I'm cleaning and repairing my original rag joint. I also have one of the last from LIC when they were making them. When I bought it, the LIC one was supposed to be the best reproduction available.
The original has the two large rivets and two bolts (first picture). When I took the bolts apart, I found that both bolts took a 1/2" wrench on the bolt heads and a 9/16" wrench on the nuts. And, both bolts have shoulders that are 7/16" in diameter. However, on the thread ends, one bolt is 5/16-24 and the other is 3/8"-24 (picture 2).
Does anyone know the purpose of using what I would consider a rather strange setup with two different sized thread ends?
Also, in doing research, I found comments from Jim Shea where he stated that he would never use bolts without shoulders on the rag joint since a straight bolt would be compressing the donut directly. I noticed that the LIC reproduction do not have bolts with shoulders.
So, my other question is does anyone know of a source for more correct bolts with shoulders.
Don
Don
