67 Rag Joint - NCRS Discussion Boards
67 Rag Joint
  • Donald H.
    • November 2, 2009
    • 2589
    67 Rag Joint
    I'm cleaning and repairing my original rag joint. I also have one of the last from LIC when they were making them. When I bought it, the LIC one was supposed to be the best reproduction available.
    The original has the two large rivets and two bolts (first picture). When I took the bolts apart, I found that both bolts took a 1/2" wrench on the bolt heads and a 9/16" wrench on the nuts. And, both bolts have shoulders that are 7/16" in diameter. However, on the thread ends, one bolt is 5/16-24 and the other is 3/8"-24 (picture 2).
    Does anyone know the purpose of using what I would consider a rather strange setup with two different sized thread ends?
    Also, in doing research, I found comments from Jim Shea where he stated that he would never use bolts without shoulders on the rag joint since a straight bolt would be compressing the donut directly. I noticed that the LIC reproduction do not have bolts with shoulders.
    So, my other question is does anyone know of a source for more correct bolts with shoulders.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 67 Rag Joint
    IMHO the bolts are different sizes as are the mating holes to prevent installing the rag joint halves 180 deg out, because there are alignment grooves etc. on the shafts that keep the system "clocked" during assembly from steering wheel to sector box.
    • Gary R.
      • April 1, 1989
      • 1804
      Re: 67 Rag Joint
      I believe that is correct. Also, Corvette Steering made the rags for LICS and I don't think they were able to source them after Tom R passed away 11 years ago.
      • Donald H.
        • November 2, 2009
        • 2589
        Re: 67 Rag Joint
        That would make sense, however if you take the bolts completely out you can reverse the halves. Since the shoulders are both the same size, you can put either bolt in either hole of the donut and reverse the whole thing.
        Don
        Don Harris
        • Donald H.
          • November 2, 2009
          • 2589
          Re: 67 Rag Joint
          I'm looking for some steel spacers that I can make into external sleeves for the bolts and try to correct the LIC rag joint I have now.
          Don
          Don Harris
          • Leif A.
            • August 31, 1997
            • 3653
            Re: 67 Rag Joint
            Don
            Don,
            Try the link below for your shouldered bolts.
            McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
            Steel Hex Head Shoulder Screws
            A zinc plating provides mild corrosion resistance. Also known as wheel and axle bolts, these shoulder screws have a hex head that can be gripped with a wrench. A standard shoulder with an undersized tolerance allows them to fit most machinery and equipment.For technical drawings and 3-D models, click on a part number.
            Shoulder
            Lg.
            Thread
            Size
            Thread
            Lg.
            Head
            Wd.
            Head
            Ht.
            Finish Tensile
            Strength, psi
            1-4 5-Up
            1 5/16" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A460 $7.13 $6.06
            1 3/8" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A480 6.87 5.84
            1 7/16" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A500 7.52 6.39
            1 1/2" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A520 7.73 6.57
            1 9/16" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A540 8.46 7.19
            1 5/8" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A560 9.19 7.81
            1 3/4" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A580 10.70 9.09
            1 7/8" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A600 11.51 9.78
            2" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A620 11.60 9.86
            2 1/8" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A640 12.20 10.37
            2 1/4" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A670 12.97 11.02
            2 1/2" 1/4"-20 3/4" 5/8" 3/16" Zinc Plated 70,000 94496A690 14.52 12.34
            1 5/16" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A210 6.85 5.82
            1 3/8" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A230 6.85 5.82
            1 7/16" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A250 6.85 5.82
            1 1/2" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A270 6.85 5.82
            1 9/16" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A290 6.85 5.82
            1 5/8" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A310 6.85 5.82
            1 3/4" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A330 8.78 7.46
            1 7/8" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A350 8.78 7.46
            2" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A370 8.78 7.46
            2 1/8" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A390 9.16 7.78
            2 1/4" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A420 9.16 7.78
            2 1/2" 3/8"-16 3/4" 3/4" 1/4" Zinc Plated 70,000 94496A440 9.16 7.78
            Leif
            • Donald H.
              • November 2, 2009
              • 2589
              Re: 67 Rag Joint
              Leif, good suggestion, but none of the shoulders are short enough. I have ordered spacers that I will cut to length.
              Thanks for the help
              Don
              Don Harris
