1967 m21 - NCRS Discussion Boards
1967 m21
  • Gary A.
    • May 31, 2001
    • 165
    1967 m21
    I recently acquired a 67 427/390 car. In researching numbers and date codes, I found a anomaly (or maybe not)on the transmission. The case is a 3885010, the vin is stamped on the trans, but the date code is stamped P7E087 rather than P7E87 the car is a May build, the rear end is correct as AZ 5-11-67. Did the assembly line guy decide to give 08 for the day?? Having lots of fun with this one. Ermine white, red interior, red stinger. great options, power steering, windows, brakes, headrests, speedminder, tinted glass, two tops, AM/FM, Posi, red lines, extra coolant (canada ), side pipes, 427/390, TI. with documentation showing all options. Needs a little love,but got plenty to give. Waited a long time for this one.
  • Patrick B.
    • August 31, 1985
    • 2003
    Re: 1967 m21
    It looks like the stamping vrersion of a typo. Clearly the day of the month should be 07 or 08, not 087
    • Mike T.
      • January 1, 1992
      • 568
      Re: 1967 m21
      Gary - Congrats on the new 67 Bigblock. Got a question for you...'extra coolant (Canada)'? Never heard of that before, can you educate me on that option? Also, we'd love to see some pics of your new acquisition.
      Mike T. - Prescott AZ.
      • Gary A.
        • May 31, 2001
        • 165
        Re: 1967 m21
        Or the error is the extra 7 for the year after the 08 day code, 087?? Who knows.
        • Gary A.
          • May 31, 2001
          • 165
          Re: 1967 m21
          Mike, Option V48 ENGINE COOLANT-INCREASED PROTECTION (ANTIFREEZE) It's in Nolands Book also
          • Gary A.
            • May 31, 2001
            • 165
            Re: 1967 m21
            Typo on the line is possible, I just realized I made one in my original post. I should have typed P7E08 not P7E87.
            • Patrick B.
              • August 31, 1985
              • 2003
              Re: 1967 m21
              Only 336 1967 Corvettes were sold new in Canada, the number of cars that got option V48 which is just a slightly richer antifreeze mix. If you don’t already have it Gary, GM of Canada will provide you documentation of your colors and options from the import documents. That makes Canada cars pretty unique, I have one too. It is a Goodwood Green L71 Convertible. Canada used different names for the same colors. The GM of Canada documentation calls it Mountain Green while the tank sticker stays with Goodwood Green.
              • Gary A.
                • May 31, 2001
                • 165
                Re: 1967 m21
                Patrick; I have a documentation from Vintage Vehicle Serices Inc. of Ontario, Canada. A gentleman by the name of George Zapora signed the document. It lists all the options, production date, ship date etc. i assume this info came from GM Canada. my car was sent to Jack Carter Chev Olds Ltd. in Calgary. Number imported for sale in Canada is 195. If I wanted to contact GM Canada to confirm, what is that process. Gary
                • Patrick B.
                  • August 31, 1985
                  • 2003
                  • Tim G.
                    • March 1, 1990
                    • 1389
                    Re: 1967 m21
                    Errors certainly do happen. This was the first year that they used a different holder for the engine and transmission stamps. My1967 427/390 was built on the 3rd day of production with VIN 350, but the transmission is stamped 349. Neither motor or transmission has been out of the car and the build date on the transmission matches the POP.
                    • Gary A.
                      • May 31, 2001
                      • 165
                      Re: 1967 m21
                      Thanks guys for the information.
                      • Patrick B.
                        • August 31, 1985
                        • 2003
                        Re: 1967 m21
                        Gary-- I see from your other thread on this car showing the documentation report that 195 refers to the number of Corvettes of the same model, namely convertibles. The rest of the 336 Corvettes with option V48 were 141 Coupes also imported to Canada.
