1962 oil pressure sending unit - NCRS Discussion Boards
  • Roger Z.
    • December 1, 1988
    • 23
    Can someone explain or send me to a site that would identify this unit
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 1962 oil pressure sending unit
    Roger,
    Not exactly sure what you're asking about. There is no such thing as an oil pressure sending unit. There is a copper plated steel line that runs from the engine block to the back of the oil pressure gauge...that's it.
    Leif
    • Frank C.
      • August 31, 2003
      • 171
      Roger, I am attaching pictures of what Leif is explaining. If stock, you should have a hard line that is approximately 1/8 inch in diameter that connects directly to the engine block near the distributor then runs through a grommet in the firewall and then to the oil pressure gauge. Hope this helps, Frank
      • Mike M.
        • May 31, 1974
        • 8408
        oil press sendinguins were used on chevy pass cars of the late 0s and on. no c-1 or c-2 vets used electric sending units. mike mccagh
