C2 Coupe Rear Harness Replacement - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5346
    I will be replacing the rear harness on a 63 coupe over the winter.
    Do I need to remove the headliner to get the new wire to the dome light?
  • Gary B.
    • February 1, 1997
    • 7077
    Re: C2 Coupe Rear Harness Replacement
    Harry,
    Not if you use the existing dome light wire to pull a good string down to serve as a way to pull the new wire back up to the light.
    Gary
    • Mark F.
      • July 31, 1998
      • 1605
      Harry,
      and if Gary's trick doesn't work, I think at most you'd have to remove (or pull down enough) the halo panel to gain access to the old wire...
      thx,
      Mark
      • Harry S.
        • July 31, 2002
        • 5346
        Just went to the car. It's simpler than I thought, just need to be careful to avoid scratching anything.
