Why a gas leak now? - NCRS Discussion Boards
Why a gas leak now?
  • Harry S.
    • July 31, 2002
    • 5328
    Why a gas leak now?
    Just put 20 gallons in the tank to store the car for the winter. I start it every two weeks to cycle the R12.
    I smelled gas, so today I pulled the tire tub.. It's leaking from the sending unit gasket!
    • 43246
    Re: Why a gas leak now?
    [ATTACH=CONFIG]114056[/ATTACH]
    [ATTACH=CONFIG]114057[/ATTACH]
    [ATTACH=CONFIG]114058[/ATTACH]
    [ATTACH=CONFIG]114059[/ATTACH]
    Harry------
    Did you use an NOS GM gasket or a current "reproduction"? Some, if not all, of the current gaskets have a slightly smaller cross section and, apparently, have been found to be problematic as far as sealing goes.
    By the way, I THINK the reason that the reproduction gaskets have a slightly smaller cross section is that this was done to address the difficulty installing the cam lock with the original gasket. If so, they succeeded in accomplishing that but.......
    • Don H.
      Moderator
      • June 16, 2009
      • 2267
      Why now?
      Because you probably have 100 other things you need to be doing right now, and there is no better time than right after you have filled the tank.
      • Harry S.
        • July 31, 2002
        • 5328
        Harry------
        Joe, what is there was in the car when I bought the car 11 years ago. All will be replaced with an NOS gasket and lock ring.
        • Tony R.
          • April 19, 2017
          • 201
          Originally posted by Don Hooper (50543)
          Why now?
          EXACTLY what I was thinking.
          • James W.
            • December 1, 1990
            • 2661
            Last year I bought a sending unit gasket for my '65 from Doc Rebuild before he went off the deep end. What I received was definitely larger in diameter than the repro from then LIC. It fit fine using the two hour oil pre-soak per the AIM, installing it with a new NOS cam locking ring and the cam lock tool I bought from LIC.
            James
            • Harry S.
              • July 31, 2002
              • 5328
              James
              Dr. Rebuild is now out of stock on those.
              • Michael H.
                • December 1, 1987
                • 730
                Like Don said you need more things on your plate heading into Winter..........
                Mike
                • Harry S.
                  • July 31, 2002
                  • 5328
                  Just took some measurements on the gasket
                  NOS Thick .2385 ID 1.868 OD 2.377
                  Rerpro Thick .2270 ID 1.789 OD 2.277
                  • Jimmy G.
                    • November 1, 1979
                    • 977
                    Murphy's Law 122 It always happens at the worst possible time
                      • 11659
                      I just installed one in the 63 with a gasket obtained from Paragon.
                      It was definitely thick, and took some effort to install. So, whoever supplies theirs likely has the sizing correct.
                      • John P.
                        • January 1, 2006
                        • 163
                        Hello Harry, disconnect the two wire connectors from the posts and see if the posts have nuts or are riveted. If you have the original threaded studs with nuts, check if the nuts are loose. I just had the same issue with my 1966. Tightened the nuts and problem solved.
                        • Harry S.
                          • July 31, 2002
                          • 5328
                          Good suggestion, first thing tomorrow.
                          • Harry S.
                            • July 31, 2002
                            • 5328
                            Patrick, you have their part number, this is what I found and it's not correct.... https://www.paragoncorvette.com/prod...ng-unit-gasket
                            • Gary B.
                              • February 1, 1997
                              • 7045
                              Paragon 3861
                              https://www.paragoncorvette.com/prod...it-o-ring-seal
