How to tell if my hood catches / latches are original or repro?
Re: How to tell if my hood catches / latches are original or repro?
Leif good work. But if it's a reverse image in your photo, it means either Ed's photo got reversed and you corrected it, or his actual stamp got reversed. I'm unsure.- Top
Here's a picture of my latch after I cleaned the grime away. I'm always curious about post's like this. My car is a '64 and was built in early Oct. '63. I bought it from the original owner and its unrestored. Sorry I can't get it any clearer. Also this is the first time I'm posting a picture. Hood Latch Marks 2.jpg- Top
I reread his post #22
He said his is stamped "19". .....
"91 vs 19..... that I did not notice but you are correct (again). How did they do that? My wild guess is that my hood latch was manufactured on a Monday morning."
Bernie just posted a photo of his early '64. His rivet is "91". More confusion.
(Bernie I rotated your photo)
Rich- Top
Leif, Back to the infamous rivet on Ed's '64....
[ATTACH=CONFIG]114053[/ATTACH]
Look, again, at the picture in your post that you corrected for Bernie. Notice on the left side of the latch mechanism the body is cut at about a 45* angle. Now, go back to Ed's picture in your post #24...the 45* angle is on the right side of the latch...a reverse/mirror image of what it actually looks like. Me thinks Ed's latch has a 91 stamped into it not a 19. Ed, if you're still watching could you clear this up for us?
EDIT:
I reversed Ed's original picture so you could see what I'm talking about.Attached FilesLast edited by Leif A.; November 3, 2022, 10:16 AM.Leif
Top Flight 2017 Lone Star Regional- Top
Leif, I see what you mean. It's like his lever is inside the frame, not outside.
Ed, please take a photo from both left and right sides of the entire latch.
Rich- Top
Here's another photo if it helps.
diamond magnified.jpg- Top
I purchased two rubber bumpers from LIC before they sold out to ZIP. My bumpers have no MFRG logos on them of any kind, just a small recessed circle on the top - they look identical to the dry rotted originals that I removed (as they crumbled in my hand). I suspect that ZIP now offers the same item.Ed- Top
Maybe the latch took a selfie in the mirror! After all, it IS a female hood latch....
Thanks Ed. Oh, just noticed your just posted reply may be a hiccup. Wrong thread? Or maybe just more info for us?
PS Thanks for the extra photo Brian. You took it off?- Top
More pics of my left hood latch assembly. But first, an potentially embarrassing explanation of the "19"..... as I think about that pic where the # appears to be a 19 vice a 91, actually...... I think I took that picture using a large mirror that I held behind the latch arm.... that was one of the few pics I took before I removed the clamp for better pics. If this has caused anyone to lose sleep, I am sorry. That said, I am attaching a bunch of pics of my left latch - which I removed again - to ensure good quality close ups. Notice that the 91 stamp is no both rivets that are used in the assembly.Ed- Top
Yep, for the past couple of years I've been completely restoring my car's chassis and suspension, and now that I'm finishing that up the work seems to have enveloped a little bit of the engine bay.- Top
