How to tell if my hood catches / latches are original or repro? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11324
    #31
    Re: How to tell if my hood catches / latches are original or repro?
    Originally posted by Brian Esch (64818)
    Circling back to the purpose/intent of the thread and given the information in post # 15, have we come any closer to being able to differentiate between an original vs a repro?
    Not really.
    You may have to actually purchase a reproduction and see how it compares.
    Or he could call Paragon and ask for a closeup photo of their "diamond" and compare it to his.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11324
      #32
      Originally posted by Leif Anderson (29632)
      Rich,
      This is a horrible close-up of Ed's picture...reversed (and, my tracing abilities are negligible). What do you think? And, we all need to get a life...spending this much time on a rivet
      Leif good work. But if it's a reverse image in your photo, it means either Ed's photo got reversed and you corrected it, or his actual stamp got reversed. I'm unsure.
      • Bernie B.
        Infrequent User
        • August 25, 2018
        • 21
        #33
        Here's a picture of my latch after I cleaned the grime away. I'm always curious about post's like this. My car is a '64 and was built in early Oct. '63. I bought it from the original owner and its unrestored. Sorry I can't get it any clearer. Also this is the first time I'm posting a picture. Hood Latch Marks 2.jpg
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11324
          #34
          Rich,
          Leif, Back to the infamous rivet on Ed's '64....
          I reread his post #22
          He said his is stamped "19". .....
          "91 vs 19..... that I did not notice but you are correct (again). How did they do that? My wild guess is that my hood latch was manufactured on a Monday morning."
          Bernie just posted a photo of his early '64. His rivet is "91". More confusion.
          (Bernie I rotated your photo)
          • Leif A.
            • August 31, 1997
            • 3633
            #35
            [ATTACH=CONFIG]114053[/ATTACH]
            Rich,
            Look, again, at the picture in your post that you corrected for Bernie. Notice on the left side of the latch mechanism the body is cut at about a 45* angle. Now, go back to Ed's picture in your post #24...the 45* angle is on the right side of the latch...a reverse/mirror image of what it actually looks like. Me thinks Ed's latch has a 91 stamped into it not a 19. Ed, if you're still watching could you clear this up for us?
            EDIT:
            I reversed Ed's original picture so you could see what I'm talking about.
            Leif
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11324
              #36
              Leif, I see what you mean. It's like his lever is inside the frame, not outside.
              Ed, please take a photo from both left and right sides of the entire latch.
              • Brian E.
                • May 28, 2018
                • 237
                #37
                Here's another photo if it helps.
                • Gary B.
                  • February 1, 1997
                  • 7024
                  #38
                  • Ed S.
                    • August 6, 2014
                    • 1377
                    #39
                    Will do. Pics coming shortly.
                    Ed
                    • Ed S.
                      • August 6, 2014
                      • 1377
                      #40
                      I purchased two rubber bumpers from LIC before they sold out to ZIP. My bumpers have no MFRG logos on them of any kind, just a small recessed circle on the top - they look identical to the dry rotted originals that I removed (as they crumbled in my hand). I suspect that ZIP now offers the same item.
                      Ed
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11324
                        #41
                        Originally posted by Gary Beaupre (28818)
                        Rich,
                        if you do a left-right mirror image of Ed’s photo in posting #12, it then looks correct.
                        Gary
                        I just did that. I wonder if Ed's camera played a trick on him, or the Exif data of the image got corrupted somehow. But unsure if that's a feature or not. Or....
                        Maybe the latch took a selfie in the mirror! After all, it IS a female hood latch....
                        Thanks Ed. Oh, just noticed your just posted reply may be a hiccup. Wrong thread? Or maybe just more info for us?
                        PS Thanks for the extra photo Brian. You took it off?
                        • Ed S.
                          • August 6, 2014
                          • 1377
                          #42
                          More pics of my left hood latch assembly. But first, an potentially embarrassing explanation of the "19"..... as I think about that pic where the # appears to be a 19 vice a 91, actually...... I think I took that picture using a large mirror that I held behind the latch arm.... that was one of the few pics I took before I removed the clamp for better pics. If this has caused anyone to lose sleep, I am sorry. That said, I am attaching a bunch of pics of my left latch - which I removed again - to ensure good quality close ups. Notice that the 91 stamp is no both rivets that are used in the assembly.
                          Ed
                          • Leif A.
                            • August 31, 1997
                            • 3633
                            #43
                            Thanks Ed...I'll now be able to sleep tonight
                            Leif
                            • Brian E.
                              • May 28, 2018
                              • 237
                              #44
                              Yep, for the past couple of years I've been completely restoring my car's chassis and suspension, and now that I'm finishing that up the work seems to have enveloped a little bit of the engine bay.
                              • Richard M.
                                Super Moderator
                                • August 31, 1988
                                • 11324
                                #45
                                Me too Thanks Ed....
                                So, it was a mirrored selfie after all ! lol
