1963 Transmissions - NCRS Discussion Boards
1963 Transmissions
  • Michael M.
    • February 1, 1993
    • 604
    1963 Transmissions
    Did all 1963 Corvettes come with Borg-Warner T-10 transmissions or did some come with Muncie transmissions?
  • Rick H.
    • April 29, 2020
    • 57
    Re: 1963 Transmissions
    They switched from Borg-Warner T-10 to Muncie transmissions in early May from what I have read.
    • Bob R.
      • June 30, 2002
      • 1595
      The 63 Muncie case is another only 63 part. The 63 case has a small bearing retainer which is designed to fit the 63 bell housing which again is different then later years. I agree with Rick's comment above that the Muncie transmission began to appear the beginning of May 63.
        • 11643
        The 63 B-W is a one year only unit as well.
        • Michael M.
          • February 1, 1993
          • 604
          The Muncie I have has a main case #3831704, left side cover #3831707, tail stock #3871731, and a date code of P0211. Does this sound correct for a Muncie from 1963?
          • Harry S.
            • July 31, 2002
            • 5293
            Post pictures of the Muncie, all sides, also, what is your cars VIN. The more information you provide the more we can assist.
            From my July 19th car:
            Maincase Casting 3831704
            Tailhousing Casting 3831731 GM 3831731
            Sidecover Casting 3831707
            Front Bearing Retainer Casting 604932 GM 18
            P0211 is February 11th.
            Michael, what are you looking to do:
            • See if the Muncie you have is original to the car, if yes, the VIN derivative should be stamped on the Muncie
            • See if the Muncie you have is a period correct Muncie and put in in your car?
            • Joe R.
              • July 31, 1976
              • 4550
              Original owner 63 coupe, 300hp, 4 speed, PS, SS and a Muncie SN 14XXX
              JR
              • Michael M.
                • February 1, 1993
                • 604
                Harry,
                I would like to unite this transmission to the car it belongs to. I wanted to find out more about it before I put in the orphan section.
                • Harry S.
                  • July 31, 2002
                  • 5293
                  Harry,
                  Michael, if there is no VIN stamped on the transmission, it's safe to say it is not from a Corvette.
                    • 43212
                    Harry-------
                    With no VIN, at all, it's likely a SERVICE transmission or, at least, a SERVICE main case.
                    • Michael M.
                      • February 1, 1993
                      • 604
                      Fellows,
                      The transmission does have a VIN. (#3200740). I didn't want to post it until I knew for sure what the transmission was.
                      • Harry S.
                        • July 31, 2002
                        • 5293
                        3200740 I believe is out of a passenger car. This is a 63 stamp 31....... Out of 63 VIN 18295.
                        Out of all the conversations I had today, that transmission came out of one of the 1.5 million 1963 Impalas produced.
                        • Michael M.
                          • February 1, 1993
                          • 604
                          Harry,
                          Thank you, I will not put this transmission in the orphan section.
