Best oil Resistant Gasket Maker Compound - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2671
    Is the Permatex Ultra Black or Ultra Gray the best oil resistant gasket maker? Need something that will work with transmission gear oil.
    James
  • Jim D.
    • 2885
    Re: Best oil Resistant Gasket Maker Compound
    This is what I use for a leak proof transmission - https://www.permatex.com/products/ga...t-maker-50-ml/
      • April 1, 2000
      • 477
      Permatex has a specialty gasket maker sealant made for gear oil. It's what I would use on transmissions and differentials. The part number is 81182 (3 oz) and 81184 (5 oz). I ofter refer to the following chart:
      • James W.
        • December 1, 1990
        • 2671
        Thanks for the input, I'll begin the hunt for the Permatex sealant that is recommended for gear oil.
        James
        • Carmen R.
          • December 28, 2011
          • 78
          James
          This is not a joke or meant to be funny, but I've heard people having very good results with this product, when everything else fails.
          https://parts.toyota.com/p/Toyota-Fo...029500103.html
          63 Coupe
            • 11692
            I used anaerobic gasket sealer as recommended by Paul at 5speeds.com
            Worked great, and easy to clean up after sealing.
