2006 Z51 Car Lug nuts - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    I have some lug nuts in shabby shape. I ordered a set of 20 from ZIP, they are nice but not even close to the same configuration.
    Anyone have a recommendation as to who produces exact copies of the 2006 lug nuts?
    • 43273
    Re: 2006 Z51 Car Lug nuts
    Harry-----
    I believe they're still available from GM under GM #19158920. However, it's possible these are a GM replacement. What do the originals look like?
    • Harry S.
      • July 31, 2002
      • 5344
      Original is on the right. Got jammed in the socket. The socket that is suppose to protect the lug nut.
      • Harry S.
        • July 31, 2002
        • 5344
        Amazing, I went to GM Parts Direct. $9.00 for two lug nuts and $67.00 shipping. Think I'll go to the Chevy dealership and see what they have.
        • Michael H.
          • December 1, 1987
          • 732
          Check with Dorman products I've had good sucess with lugs nuts from them.
          Mike
          • Harry S.
            • July 31, 2002
            • 5344
            Mike
            Mike, Thank you
            • Peter H.
              • April 1, 1980
              • 230
              Harry The Lug Nuts You Received Are A Cheap Chrome Plated Replacement Not Stainless Steel Capped Like Your Originals. Check With Your Chevy Dealer Who Should Have Outside Suppliers Who Have The Capped Version. When I Was The Buyer For The Dealership I Had A Great Source For Good Replacement Look Alike Nuts. Good Hunting Peter 🇨🇦
                • 43273
                Harry------
                The GM lug nuts of the aforementioned part number appear just like your originals. If your GM dealer does not stock them they should be able to order them for, at most, GM list price (about 5 bucks, each) and no shipping charge.
                  • 43273
                  Mike
                  Mike------
                  The Dorman replacement lug nut is of the original configuration. However, the original is of a 2 piece design with integral cap bonded in some way to the nut, itself. The Dorman maintains original configuration but is a 1 piece design. From a functional and durability perspective it's probably better than the original. However, I don't know if it's detectably different.
                  • Harry S.
                    • July 31, 2002
                    • 5344
                    Harry------
                    Thank you..........
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11363
                      Harry I just checked gmparsgiant.com too. $97 shipping for 5. But.....
                      Looking at the specs. It shows "WEIGHT 26.4" (with no unit of measure)
                      I bet it defaulted to pounds. So your 2 lugnuts cost $67 to ship 52.8 lbs.
                      Probably give GM Parts Direct a call to get it corrected.
                      Rich
                      • John D.
                        • June 30, 1991
                        • 875
                        This is what i find in the GM catalog for 2006 Corvette lug nuts. It shows availability in all GM warehouses.
