61 Trunk Drain Hole - NCRS Discussion Boards
61 Trunk Drain Hole
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: 61 Trunk Drain Hole
    Originally posted by Mark Swanson (6796)
    Thanks Rich!
    Richard: I sent you an email; and I hope it went through. Thanks! Mark
    Richard:
    Any luck on finding the plug?
    Thanks!
    Mark
    I am not very proficient in using this email.
    Mark I'm back home. I just sent you a email. Posting here so you get TDB notified in case my email gets spammed.
    Rich
    PS Good news... I found it!
    • Mark S.
      • July 31, 1983
      • 666
      Rich:
      I sent you an email. Please let me know if you did not receive it.
      Thanks!
      Mark
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11366
        #18
        Mark I got your email and address. I'll send it out 1st Class USPS padded envelope, hand stamp only. I'll drop you a note when it goes out.
        So... since it's my last one, and before I packaged it up, I did a quick hen-scratched drawing with dimensions for future reference. Also note deep in the bottom of the plug is a letter "P" inside a circle. Must be a manufacturer marking. The last photo showing the P was through a magnifier, backlit above a flashlight for a clear view. Since this part was used for 1961/1962(qty 3), and 1966L-1967 without RPO A85(qty 2), there were likely other manufacturers so the "P" may not be on every part in existence.
        Rich
        • Mark S.
          • July 31, 1983
          • 666
          #19
          Ed:
          Thank you very very much! I really appreciate your help and assistance!
          Sincerely,
          Mark
          • Russ S.
            • April 30, 1982
            • 2163
            #20
            Mark, Have you tried shining a light from the under side to locate the hole? Often you can see the original hole location that way.
            • Mark S.
              • July 31, 1983
              • 666
              #21
              Russ:
              Thanks! I did locate the location and a new hole has been drilled.
              Mark
