Seat Belt safety cable rubber grommet - NCRS Discussion Boards
  • Garry B.
    • January 1, 1991
    • 660
    Any ideas on how to recreate the rubber cable grommet on a '67 seat belt safety cable. This is the cable that is installed though the frame just forward of the rear wheels. Thanks.
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
  • Robert M.
    • January 1, 1992
    • 78
    Re: Seat Belt safety cable rubber grommet
    Hello Garry,
    I used black electrical heat shrink tubing
    Bob
    • Keith B.
      • September 15, 2014
      • 1591
      I make a shallow tank and dip it the rubber tool dip sold at handwear stores. several coats and some t******* it will look good
      • James W.
        • December 1, 1990
        • 2669
        I use the 1/2" to 1/4" black heat shrink tubing material cut to 2-3/4" to 3" in length.
        James
        • Thomas N.
          • July 31, 2002
          • 402
          Here's a writeup of what I did with my seat belt cables.
          Seat Belt Cable Assemblies.pdf
          NCRS New England Chapter Chairman 2022, 2024
          N E Regional Chairman 2024
          1967 Corvette Convertible Under Restoration
          1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
          • Garry B.
            • January 1, 1991
            • 660
            I have a question, is the outer bolt that threads into the frame captured by a welded nut on the inside portion of the frame? In other words, if I just take the bolt out will I drop the nut on the other side? I think it's welded, but not sure.
            Garry Barnes #18531
            • Thomas N.
              • July 31, 2002
              • 402
              It is a welded nut. Unless it is so rusty that when removing the bolt you break the resistance welds, and it then floats around.
