63 U-joints - NCRS Discussion Boards
63 U-joints
  • Todd L.
    • November 25, 2020
    • 298
    63 U-joints
    Hey guys,
    In the 63-64 JM page 206 under "Driveshaft & Half Shaft Assemblies" there is a line that says (Half shafts attach to the differentioal output yokes with a flat cap and black phosphate or natural steel "U" Bolts, lock washers and nuts.)
    What is the "flat cap" referring to? Is that saying the U-Joint caps should be flat, not with an indention? If so, would this be for driveshaft and half shafts both?
    Thanks!
    Todd
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 993
    Re: 63 U-joints
    That refers to the U-joint caps. The production U-joint caps were flat....not stepped as commonly seen on modern replacement U-joints.
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
    • Todd L.
      • November 25, 2020
      • 298
      Re: 63 U-joints
      Thanks Tony,
      Looks like I have some modifications to do!
      • Tony S.
        • April 30, 1981
        • 993
        Re: 63 U-joints
        On occasion, Paragon sells flat capped U-joints with no zerks. You might try them. Good luck!
        • Todd L.
          • November 25, 2020
          • 298
          Re: 63 U-joints
          Ok, thanks for the reference.
          • Alan D.
            • January 1, 2005
            • 2053
            Re: 63 U-joints
            Here is what to look for, the actual cups are a little smaller also, but can not tell without a gauge.
            • Todd L.
              • November 25, 2020
              • 298
              Re: 63 U-joints
              That's great, thanks so much for the pictures, that really helps. Is that an unrestored driveshaft with factory paint markings or has that been done after the fact?
              • Alan D.
                • January 1, 2005
                • 2053
                Re: 63 U-joints
                Basically an original, however black goop removed, soaked in rust remover (Rid Rust now Safest Rust ultraoneusa.com) which does not remove paint, and new paint (same color) added at the remnant locations.
                • Todd L.
                  • November 25, 2020
                  • 298
                  Re: 63 U-joints
                  Great, thanks for the detail on this Alan!
