Question on 69 sb ign shielding - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
    Guys,
    I'm putting my ign shielding on my 69 sb restoration and I noticed there is nowhere to bolt the lower driver's side descending shielding to. The AIM has an "existing support" it calls out for the shielding to be bolted to but I don't see where that could be. The only thing in this area is the spark plug wire loom that bolts to the back of the block but there is nowhere to bolt the shielding to this bracket. I have attached the pic from the AIM. Does anyone know what the "existing support" called out in the AIM is?
    Mike
    • 43290
    Re: Question on 69 sb ign shielding
    Originally posted by Michael Leonard (46610)
    Guys,
    Mike
    [ATTACH=CONFIG]112414[/ATTACH]
    Mike------
    The "existing support", if you have the correct GM #3923971 support, does have a tab with a hole for the "wing screw".
    • Michael L.
      • December 15, 2006
      • 1424
        • 15643
        The "existing support" that Joe L. and the AIM referrs to is a support bolted to the engine at Flint engine. Thus, it is "existing" relative to the employees at St. Louis.
        • Michael L.
          • December 15, 2006
          • 1424
          Thanks Terry. I'm pretty sure I have that bracket. I think I may have used two of the same (passenger side) spark plug wire holders instead of the one I should have used on the drivers side.
          • Michael L.
            • December 15, 2006
            • 1424
            Terry were these attached when the engine was painted? Are they, and their attaching bolts engine orange? Looked through the JG and can't seem to fine anything on these specific brackets but I might have just missed it.
              • 43290
              Michael-------
              They were not painted.
              • Michael L.
                • December 15, 2006
                • 1424
                Thanks Joe. What's the finish if not painted? Cad/zinc plated?
                  • 43290
                  • Michael L.
                    • December 15, 2006
                    • 1424
                    Great thanks Joe.
