P01 vs P02 - NCRS Discussion Boards
P01 vs P02
  • David M.
    • September 30, 2004
    • 533
    P01 vs P02
    All,
    I know this has been hashed out here probably more than twice. However either I'm not using the search feature here correctly or it sorely lacks the ability to find this simple query.
    Google and other forums provided conflicting info...of course.
    1st picture:
    Is this a P01 = 68 production only? >edit(I think very possibly)<
    The ribs are rounded off where they meet the center cap? And the center cap is not flush with the turbine fins.
    AG Ralley rims should be under it, not standard black rims w/o the ralley slots? edit>(As stated below Ralley rims were the only wheel offered in 68)<
    Same cross flag center cap as the P02? >edit(Still unanswered)<
    2nd picture:
    P02 = 69-72 Production. edit>(I believe this is correct)>
    The ribs squared off where they meet the center cap. The center cap is flush with the turbine fins.
    Ralley rims were also found under the P02s. edit>(yes as started below)<
    P01 & P02 centers are identical? >edit(Still unanswered)<
    The optional finned wheel cover found on the late 69 and early GM big cars 70-72 Monty Carlos, Caprice, Riviera's etc shared the same outer rim and fins as the Corvette P02. The differences are the center caps. Chevy big cars centers were flat and held on with speed nuts. edited>(corrected for accuracy)<
    The 14" F body Chevy/Buick optional deluxe caps are the same for those two cars with exception of the Buick or Cross Flags. These 14" caps are completely different from the 15" caps. Different turbine fins, different centers and different outer rim profile. Side by side its obvious.
    TX
    Dave
    Edited 13MAY24. I learn as I go. I restore and collect these...
    Last edited by David M.; May 17, 2024, 12:02 PM. Reason: New info to provide accurate data
  • Mike E.
    • February 28, 1975
    • 5141
    • Leo G.
      • August 31, 1987
      • 116
      Re: P01 vs P02
      I am confused. The last photo has what appears to be a Buick crest on the center cap. .???
      Drive safe
      Leo
      • David M.
        • 533
        Re: P01 vs P02
        All to my point which cap is a P01? Pointed ribs or square? edit 13MAY24>(I do know the square fins are P02 in the above pictures)<
        Mike that's what I understood for 68, AGs only regardless of P01 or not. Good to know 14s are out there too, I'm thinking 70-72 gen 2 Camaros.
        What about 69-73, Ralleys under the PO2s as well?
        Leo correct you are seeing a 14" Buick cap in the last pic. Also Chevy big car caps(set of 4). The Chevy big car and the Buick caps appear to be the same cap structure, outer ring and cast insert, as a P02. Only difference is center.
        Last edited by David M.; May 14, 2024, 09:12 PM. Reason: Updated to provide accurate data
        • James G.
          • August 22, 2018
          • 808
          Re: P01 vs P02
          The outer polished band is different on the Buick cover.
          The outer band differs in that there are multiple ridges on the Buick profile where as the Corvette cover only has a single step on the outside of the outer trim band.
          • Tim G.
            • March 1, 1990
            • 1414
            Re: P01 vs P02
            The fins come to a point on PO1 hubcaps. They are square on PO2 hubcaps. Late 1968 Corvettes used PO2 hubcaps, but they were still listed as PO1 on the paperwork.
            • James G.
              • August 22, 2018
              • 808
              Re: P01 vs P02
              Another difference
              • David M.
                • 533
                Re: P01 vs P02
                Ahh yes I see the differences. Thanks James & Tim. I'm trying to educate myself as I am looking for a set of P01s but Ill take P02s in decent shape.
                The Buick cap is a 14".
                Had a craigslist fella try to BS me he had Corvette P02s until I had him measure, they were 14" with flat centers and the rib feature on the outer rim.
                The 14" are for 70-74 Camaros and Apollos. edit>(Correct)<
                Looks like the closest thing GM made to a PO1/PO2 would be the 15" big car caps. See the set of 4 above.
                • Tim G.
                  • March 1, 1990
                  • 1414
                  Re: P01 vs P02
                  I just bought a 1970 and put a set of PO2's on it. A friend had four of them in a box dated 1974 and three of the boxes were never opened. They look great on the right car. I may be a fool, but they were $1,000 for a never mounted set.
                  • Ed H.
                    • July 19, 2014
                    • 58
                    Re: P01 vs P02
                    Great looking car Tim. The P02s do look good on that Monza red.
                    Ed
                    • Tim G.
                      • March 1, 1990
                      • 1414
                      Re: P01 vs P02
                      Thank you, Ed.
                      • James G.
                        • August 22, 2018
                        • 808
                        Re: P01 vs P02
                        You're no fool, nice used sets, with minor restoration will bring $500-600 easy.
                        The differences would be easy to spot side by side.
                        • Blair K.
                          • September 27, 2012
                          • 170
                          Re: P01 vs P02
                          I would be interested in buying your PO2s' boxes - let me know. Thank-you.
                          • Tim G.
                            • March 1, 1990
                            • 1414
                            Re: P01 vs P02
                            Blair, I want to keep them in the event I go back to rally wheels. I'm storing the trim rings and caps in them now.
                            • Sal C.
                              • December 1, 1984
                              • 430
                              Re: P01 vs P02
                              James, the photo of the Buick cap is a 14 inch, hence the difference.
