C3 splash shield mounting rivets - NCRS Discussion Boards
  • Justin S.
    • July 3, 2013
    • 305
    What type of gun works on these rivets?
  • James G.
    • August 22, 2018
    • 808
    Re: C3 splash shield mounting rivets
    No type of gun sets those.
    If not mistaken it requires an air hammer and bucking bar.
    James A Groome
    • Bob R.
      • June 30, 2002
      • 1595
      They are made of soft aluminum and as noted above you can use an air hammer with a bucking bar. The aluminum is so soft that you can also use a hammer and back up the rivets with some type of steel plate.
      • David B.
        • March 1, 1980
        • 690
        If that rivet is the one you plan on using for splash shield installation you might want to double check if correct type. Per UPC 1 sheet D9 rivet #9409244 is a #100 countersunk head aluminum rivet 3/16 X 7/16 pointed head.
        • James G.
          • August 22, 2018
          • 808
          FWIW I set some 1/4" dia STEEL rivets yesterday for a bracket on a bumper, it took more time to get out the tools and set up for the job than it did to set the 2 rivets.
          James A Groome
