62 overheating - NCRS Discussion Boards
62 overheating
  • Roger B.
    • June 30, 1991
    • 82
    62 overheating
    My rebuilt 327/300 62 engine runs 220+
    new water pump
    new hoses
    whst am I missing
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 62 overheating
    Maybe the Thermostat, sending unit or bad gauge! Just a few off hand thoughts!
    • Don H.
      • December 1, 1981
      • 1496
      Re: 62 overheating
      Have you verified the temperature with an IR gun?
      • Gary S.
        • July 31, 1992
        • 1633
        Re: 62 overheating
        For an "in the ball park" check, Harbor Freight sells in IR gun for $29 which would allow you to compare upper and lower radiator. I chased an overheating 66 until my HF IR gun proved that my radiator was not up to speed.
          • 15706
          Re: 62 overheating
          Round up the usual suspects:
          1. Spark advance map (VAC and initial timing)
          2. Fan clutch
          3. Radiator deposits that reduce heat transfer.
          Less likely, but still possible:
          4. Thermostat malfunctioning
          5. Incorrect or corroded water pump impeller that reduces coolant circulation rate.
          6. No spring in the lower radiator hose that prevents it from collapsing and blocking flow.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17940
            Re: 62 overheating
            Roger,
            Ditto everything everyone's said.
            Did you remove the thermostat and fill the block with coolant, replace and then fill the radiator to make sure that the block and radiator were full of antifreeze with no void.
            Best thermostat to use is a Robert Shaw. If you don't have one, recommend you get one.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
