'67 Interior Rear View Mirror Glass Replacement - NCRS Discussion Boards
  • Owen L.
    • September 30, 1991
    • 885
    Just a note to relate my experience changing the glass in my '67's mirror. The original glass was so tarnished that it was pretty useless, especially at night. I ordered replacement glass from MidAmerica Motorworks for ~$34 with shipping.
    The old glass came away from the housing fairly easily after warming the rubber surround in hot water and working a plastic epoxy mixer/spreader behind the glass. Comparing old glass with new showed obvious shape differences with the new one being at least 1/8" too tall and ~3/16" too wide with the top curve being off. Thickness seemed OK and pretty similar between the two - though it's tough to tell since they both have wedge profiles for the Day/Night feature.
    Using a stained glass wet grinder, I was able to use the old glass as a template on the new and grind the new glass to the correct shape. For anyone with glass replacement in the future, look to see if a glass shop or stained glass maker will profile the replacement for you should it arrive like mine.
    After polishing the stainless housing with Mother's, the new glass went in without much trouble and fit perfectly. Remounted in the car and... VOILA, crystal clear rear view!
    As an aside, how do folks set the day/night angle? For night driving, flip the lever to tilt the mirror upward or flip it so the mirror tilts downward? I've always flipped it up so the bright reflections hit the car's headliner.
  • Mike E.
    • February 28, 1975
    • 5141
    • Owen L.
      • 885
      Re: '67 Interior Rear View Mirror Glass Replacement
      Thank you, Mike, for the additional info. It was easy enough for me to regrind it rather than go to the trouble and frustration of returning it, plus, I didn't know if all vendors were selling the same thing so would be in the same place down the road. It probably won't do any good, but I'll leave advisory feedback on their eBay store.
      For others reading this thread, if anyone finds a true-fitting replacement, please post the source.
      • Leif A.
        • August 31, 1997
        • 3646
        /\/\/\This...accurate parts are getting harder and harder to source...truly unfortunate and rather ridiculous.
        Leif
        • Mike M.
          • May 31, 1974
          • 8402
          I got several replacement mirrors for my 67's yard ago and had no trouble at all of replacing them in original mirror bases. as I recall, ak then , I'd have gotten them from Corvette central or paragon. mike mccagh
