Door locks 68 vette - NCRS Discussion Boards
Door locks 68 vette
  • Ed H.
    • March 25, 2022
    • 6
    Door locks 68 vette
    I have a 68 vette the key will not unlock the door I took the locks out and still unable to turn the tumbler, as you know this was a 1 year push button lock open no one I've found sells after market ones. Used ones are almost non existence. Can the tumbler be rebuilt I live in Spring hill Fl. If you know old time lock Smith. Thanks Ed
  • Gary B.
    • February 1, 1997
    • 7069
    • Ed H.
      • March 25, 2022
      • 6
      Re: Door locks 68 vette
      Sorry Gary limited computer skills don't know how to post pictures. The locking mechanism and the push button to open the door are 1 piece made only in 1968. Thanks for responding Ed
      • Gary B.
        • February 1, 1997
        • 7069
        The only way GM sold the ‘68 door lock push buttons to the public was as an uncoded lock. The GM part number for the service part is [COLOR=#0000FF !important]3936223[/COLOR]. Since the service lock is uncoded, that means the lock was intended to be coded to a specific key by the end user. Which means a locksmith can do it. That also means a used lock can be serviced.
        Since that push button lock was a one-year only item, finding NOS examples of those locks is notoriously hard. If I were you, I would take your current locks to a somewhat senior locksmith and get an expert to try to make them work properly.
        Gary
        Gary
        • Brad Hillhouse (37766)
          Ed - Quick question, are you using the ignition key to try and open the door locks as designed originally? The 68 is different than later Corvettes that used a seperate key for the door lock and the ignition cylinder.
          On my original 1968 door lock cylinders, there was a factory 4 digit "key number" that I was able to use to get the 6 digit key cut code and have additional keys made directly for the cylinder instead of making a copy of the copy. I wonder if your numbers are still visible on the lock cylinder you could use to have the key made?
          Brad Hillhouse
          • Gary B.
            • February 1, 1997
            • 7069
            • Ed H.
              • March 25, 2022
              • 6
              Thanks for reply. That is a possibility I thought of , I had a 68 afew years ago that had the same problem I soked them in wd 40 and got 1 to work, never could get the other one to work.. Never could find a lock Smith interested in repairing it.. The ignition key is a GM key and looks fairly old ,round key fits tire lock and back compartment doors. I'll keep trying to find a old time locksmith. Thanks again for the help Ed
              • Gary B.
                • February 1, 1997
                • 7069
                Ed,
                The roundish key for the tire lock and glove lock should have a letter D stamped into the blade. The door and ignition key should be octagonal with the letter C stamped into the blade. Something sounds very odd about your keys. Finding a good locksmith is the best advice I can give you.
                Or look thru the DB FAQ page and read about how to post photos and then post some photos of your keys.
                Gary
                • Ed H.
                  • March 25, 2022
                  • 6
                  Thanks for the help look forward to talking to in the future. Ed
                  • Ed H.
                    • March 25, 2022
                    • 6
                    I'll look thanks for the info. ED
                    • Ed H.
                      • March 25, 2022
                      • 6
                      Update on door locks I found an old locksmith 45 years experience. Turns out he was able to dis assemble the lock and make a new key. If you need any locksmith in Hudson Fl. All safe locksmith is a good experienced one. Thanks for all your help Ed
