1964 C2 Motor Authentication - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 1964 C2 Motor Authentication
    Just a statement and a few questions: Just looking to help figure out what this is!
    1) Why would anyone fake a 250 hp base engine.
    2) what heads are on the car, power pack?
    3) what size is the exhaust and the center exhaust hanger. 2 inch or 2.5 inch.
      • 11659
      That is correct Gary. Those Tonawanda cast cylinder cases that were sent to Flint for machining and assembly had that tapped and plugged hole in spite of their Tonawanda cast beginnings. The machining operation and location dictated that feature.
      Agreed.
      I just pulled up the pictures of my 1972 Tonawanda block, and it has the Flint-type plug and the rear lip is not machined.
      • Tom R.
        • June 30, 1993
        • 4100
        #18
        Is it being suggested there are no absolutes?
        Tom Russo
        โ€‹
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Patrick B.
          • August 31, 1985
          • 2002
          #19
          I think we are being open to the possibility that there is always something new to learn about Corvette history. This block is suggestive that some 1964 model year Tonawanda block castings were machined in Flint. I am sure when the same idea was brought up about 1965 and 1972 Tonawanda blocks, some strong proof was needed. In this case we still need to see the machining at the rear of the block or some other example of a Flint stamping of the same day and usage code. It is still possible that the front plug was installed on an ordinary Tonawanda passenger car block to make it look correct for a Corvette, but the odds seem good that it is a legit block and a formerly unknown permutation.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11329
            #20
            I've put the 2 photos from my earlier post in the same orientation for comparison.
            The Tonawanda Pass car reference block, Tonawanda machined.
            The Tonawanda block in Michael's car, Flint machined.
            Rich
            • Patrick B.
              • August 31, 1985
              • 2002
              #21
              [ATTACH=CONFIG]111059[/ATTACH]
              [ATTACH=CONFIG]111060[/ATTACH]
              Rich
              Good observation, Rich. This certainly supports the prospect that this block was machined at Flint. It has the big numbers for 3782870 (oddly upside down) like Flint blocks, unlike your Tonawanda example. Actually, the only Tonawanda feature the block has is the casting year expressed in two digits rather than one. Looking at it from the other direction, could this be an oddball Flint casting with an upside down casting number and an unusual date tag on the wooden pattern used to make the sand mold?
              On second thought, the OPโ€™s pictures show a 4T in the casting next to the shift hour clock symbol. Does this T stand for Tonawanda? Are the any other places to look for a T symbol on a Tonawanda cast block?
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11329
                #22
                I found some 1964 engines close to Michael's vin/assy date. Unsure of the validity. They were on the c2registry.
                Here's is Michael's.
                #10314
                #10253
                #09956 (Note the "4" and compare to Michael's)
                • Patrick B.
                  • August 31, 1985
                  • 2002
                  #23
                  Since a stamp holder was set up each day for each usage code, only the holder for RC on that day would contain the same array of character styles. But the RC holder for a few days before or after Jan 4 may contain many of the same characters in the same order.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11329
                    #24
                    Good point. Thanks Patrick.
                    • Mark F.
                      • July 31, 1998
                      • 1563
                      #25
                      1. 04 (Jan 4th18 (Jan 18th24 (Jan 24th)
                      #2 is 61 VINs BEFORE #1; but the engine assembly stamp is 14 days AFTER #1
                      #3 is 358 VINs BEFORE #1; but the engine assembly stamp is 20 days AFTER
                      thx,
                      Mark
                      • Michael W.
                        Infrequent User
                        • July 14, 2020
                        • 9
                        #26
                        I know this is not proof, but I have a binder full of documents like these that make it difficult for me to believe there has been a motor swap. Or if they did swap the motor, why would someone go to all the trouble to forge a stamp pad so perfectly in such a low option car?
                        • Patrick B.
                          • August 31, 1985
                          • 2002
                          #27
                          Your engine is very unusual as a Tonawanda block machined in Flint, and it took a little longer than usual to get from the engine assembly in Flint to installation at St. Louis. However, for what its worth, I am convinced like you that it is original.
                          • Mark F.
                            • July 31, 1998
                            • 1563
                            #28
                            Very cool to see how many miles this puppy apparently has on it - and to so many cool places as well in a 3-speed!
                            It would be nice to see a shot of the car, too!
                            thx,
                            Mark
                            • Harry S.
                              • July 31, 2002
                              • 5330
                              #29
                              Michael, I see in the paperwork that an AM/FM radio was ordered. What radio is in the car?
                              • Michael W.
                                Infrequent User
                                • July 14, 2020
                                • 9
                                #30
                                The original Delco
