I'm Mike Webster. I own a '64 C2 and have been unable to authenticate my motor.
Data:
VIN# 401867S110314 Final assembly early February 64
Engine Pad: 4110314 F0104RC Jan 4, 1964
Cast# 3782870
Cast Date Code: L1663 Dec 16, 1963
327/250
3-sp Saginaw Transmission
Engine stamp pad and casting identification markings appear unaltered. The motor has the square plug forward of the intake manifold verifying it is a Flint machined/assembled block. I'm the third registered owner of a 66k mile car.
The judging manual says all C2 motors were cast in Saginaw, machined/assembled in Flint. The only rare exception are those blocks cast in Tonawanda with a casting #3858180, all being machined/assembled in Flint. My 3782870 block was cast in Tonawanda, machined/assembled in Flint.
I contacted Al Greening, he was unable to authenticate my motor because there are no other examples in his database. I am curious if any member owns or knows of a '64 C2 built approximately the same time as mine with a 3782870 Tonawanda cast block. I'm looking at a vin sequence around 10,000-10,500.
Appreciate any help in this matter. Thank you.
Data:
Cast# 3782870
327/250
I only wanted to point out what we have seen in the early C3 cars. If one chooses to stretch that information into C2s, one does so at their own risk.
