knock off center caps - NCRS Discussion Boards
  • Mel S.
    • August 31, 1992
    • 264
    I bought 66 bolt on knock offs for my convertible. Everything is on but I cannot get the center cap to "snap" into the spinner. The directions states that you put the cap into the groove of the spinner and "snap" it into place. There are three tabs on the spinner. When I put the tabs into the spinner, they seem to "bottom" out on the spinner BEFORE they can be recessed enough to "snap" into place. Has anyone ran into this issue? Any help would be greatly appreciated.
    Mel
  • Harry S.
    • July 31, 2002
    • 5344
    Re: knock off center caps
    Mel
    Has the aluminum safety pin bottomed out? If not that may be the issue.
    • Bill W.
      • November 1, 1977
      • 402
      Mel,
      Like most reproduction parts, those caps "almost " work. Other than that they are a decent repro part. Here's how you make them fit. Take a piece of plate glass large enough to hold a wet sheet of 220 grit wet/dry sandpaper. Place the center cap on the sandpaper the and start sanding the bottom edge. Each cap will require approx. 10/15 minutes of sanding to remove enough metal for the three clips to snap into the groove in the spinner. Good luck when it comes time to remove them as they are easily damaged. All this is another reason I NEVER use the anti-theft pins. Bill
      • Gary B.
        • February 1, 1997
        • 7068
        Mel,
        Which brand of knock offs did you buy in the end? Ones from AFC? Or from Top Flight/ Corvette America?
        Gary
        • Mel S.
          • August 31, 1992
          • 264
          Unfortunately the pin is not interfering but thanks for the input
          Mel
          • Mel S.
            • August 31, 1992
            • 264
            I bought them from Corvette Central which was delivered from the manufacture Auto Accessories of America
            • Robert B.
              • March 1, 1992
              • 265
              Mel
              I just installed mine. You will need rubber mallet a little WD40 and a very small screw driver.
              try and get one tab in the groove and place the tip of the screw diver on the side of the other tab, not on the tab, between the cap and mating part and give it a whack on that edge and it will pop right ii. A real nice tight fit in my eyes .
