Fuel injection, etc Tip - NCRS Discussion Boards
  • John D.
    • November 30, 1979
    • 5507
    I have learned a lot of things from John Hinkley. But here is one of the best tips that I am forever grateful for.
    On the'57-'65 FI's I use his recommended water outlet gasket. GM #10105135. It's black and fits the contour of the water outlets perfect. It has a bead of sealant on both sides. You don't have to over tighten the two nuts or bolts to make a perfect seal.
    John said as long as you get the outlet reasonably flat you will never have a leak using this gasket. Now I use my machinists granite surface plate to make the outlets perfectly flat. Not easy on a cast iron one. John D.
  • Gary B.
    • January 31, 1997
    • 6985
    • John D.
      • November 30, 1979
      • 5507
      Re: Fuel injection, etc Tip
      Gary, I do not know.
      • Gary B.
        • January 31, 1997
        • 6985
        • Gary B.
          • January 31, 1997
          • 6985
          John,
          In a 2007 posting, Joe Lucia says that gasket will fit all 55-91 Corvette V8s.
          Gary
          • James W.
            • November 30, 1990
            • 2640
            Just bought two of them for $3.43 each on Amazon with free Prime Member shipping. Be here onn Friday.
            James
            • Gary B.
              • January 31, 1997
              • 6985
              James,
              Me too. Also from Amazon for $3.74 with tax. It will be at my door on Thursday. What a country!
              Gary
              • Don H.
                • November 30, 1981
                • 1482
                I ordered some from my local GM dealer & had to order 10. I was not happy at the time (2019) but have already used 3 (1 to a friend) so I guess it was a good purchase. Don H.
                • Leo G.
                  • August 31, 1987
                  • 116
                  John,
                  Thanks very much for taking the time to share the info. Appears I will be ordering some. Thanks again !
                  Leo
                  • Gary B.
                    • January 31, 1997
                    • 6985
                    • John D.
                      • November 30, 1979
                      • 5507
                      Thanks for the nice compliments. I also buy Stant 180 thermostats and use those along with the GM gasket. John
