Questions for Judges and seek opinions of others - NCRS Discussion Boards
  • Philip A.
    • September 18, 2021
    • 94
    To help combat the interior heat issue on my boy, Blue (69 L68), how would the lizard skin spray insulation coating affect judging, value and resale by spraying the interiors toe boards, floor pans and rear floor of the compartment area.
    Would this prevent you from buying a car with it?
    TIA
  • Brian D.
    • April 30, 1999
    • 425
    Re: Questions for Judges and seek opinions of others
    If it's not visible or easily detectable, I can't imagine judging would be affected.
    If judging isn't affected, I can't imagine it would be a negative impact on resale.
    The NCRS types wouldn't mind, and the non-judging buyers wouldn't care.
    B.D.
      • 43286
      TIA
      Philip------
      Does this car have tubular headers or stock exhaust manifolds?
      • Philip A.
        • 94
        Joe,
        Stock exhaust manifolds with N14 option
          • 43286
          Joe,
          • Philip A.
            • 94
            Joe, I would never have thought my feet would get as hot as they do with the n14. The amount of heat at the footboard is ridiculous.
            So, what's your thoughts on the lizard skin?
            • Michael B.
              • June 18, 2007
              • 400
              It's a big job but have you considered checking and replacing the seals on your blend doors in the heater box? Hot water constantly flows through the heater core and leaky seals could be your source of heat.
              • Chuck G.
                • May 31, 1982
                • 2039
                My wife and I had a 69 427/400 HP convertible with factory side exhausts. Never bothered us much when we lived in Maryland. We moved to Florida in 2009. Found we rarely drove the car due to the cabin heat and especially the floorboard heat.
                Those factors, coupled with the warm climate in Florida relegated the car to the top of my four post lift. We sold the car to a fellow in S. Carolina in about 2015.
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17954
                  Restorer article on floorboard insulation.
                  Gary
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                  • Bill M.
                    • 1329
                    Phil try wrapping the pipes with exhaust insulation see if it helps.
                    • Harry S.
                      • July 31, 2002
                      • 5346
                      Install a hot water shutoff to keep the hot water out of the heater core.
                        • 43286
                        Philip------
                        It might help if you applied it to the under-carpet floorboards, especially on the area proximal to the side exhaust.
                        • Floyd B.
                          • November 1, 2002
                          • 1051
                          True, unless it's a C60 car. Then there is a cut-off valve when the a/c is on so that the a/c evaporator isn't at war with the heater core. But that assumes the valve isn't stuck.
                          "Drive it like you stole it"
