Re: 1969 Engine Wiring Harness Replacement - will not fire
Hi Richard - Yellow wire resistance tested well = 0.1 ohms.
Wiggled the distributor white/green and white wires while checking resistance across this circuit - maintained right at 587 ohms.
How do I ohm test each wire to ground?
