2004 Z06 Battery Configuration - NCRS Discussion Boards
  • Frank E.
    • May 31, 1986
    • 189
    In getting my Z06 ready for judging I don't understand the TIMAG description for the 50% deduction on non-original Delco battery replacements. it says "In order to receive the standard 50% deduction for a current Delco replacement battery in a 2004 corvette the Battery is ACDB24R AGM." My original battery is a group 86 which you can't get any more. When I replaced my original, all I could find was a Group 86PG. I've attached a picture of my original for clarity and my current battery that needs replacing. Any suggestion as to which Delco replacement I need????
    Thanks...
    Frank
    1966 Milano Maroon Roadster
    2004 CE Z06
    • 11692
    Re: 20004 Z06 Battery Configuration
    You can still buy the 86 as G, PG or PS, and that's the size that ACDelco suggests for your car.
    The batteries likely change faster than the manuals, so I'd go with an 86.
    • Frank E.
      • May 31, 1986
      • 189
      Frank
      2004 CE Z06
      • Guest
        I would recommend the Delco group 86 and go with the PG series
        The PG deignation has more CCA and carries a full 4 year replacement not prorated
        I use this series in all my Corvettes no matter the group size
        Mark
        • Frank E.
          • May 31, 1986
          • 189
          I don't have it any more. But that would be a great thing to do...... Darn
          Frank
          2004 CE Z06
          • Joe W.
            • February 1, 2011
            • 43
            Frank: My 2004 Z06 was judged at a Chapter meet in 2021 with the Blue AC Delco 86PS Battery and this past Saturday at the Lakeland Regional with the Gold AC Delco 86PS Battery. Both times I received a 50% deduction. Notice that the same number 88865255 appears at the bottom of both labels. Also, both batteries were purchased from my local Chevy dealer after they looked up the correct battery replacement for the car.
            Joe Wick
            • Frank E.
              • May 31, 1986
              • 189
              Great info, Joe..... I appreciate it. I am going with the 86 group and will pick it up this week....
              Frank
              2004 CE Z06
