66 wheels - NCRS Discussion Boards
66 wheels
  • John B.
    • April 20, 2021
    • 111
    66 wheels
    Hello all,
    I have been researching if my wheels are correct on my 66 427/390. They are silver steel wheels with the rings and center caps. They do have the "GM" "KH" stamps. From what i have read the wheels were black.
    Does anyone have some good information for me?
    Mike
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: 66 wheels
    66 had either "knock off" wheels with a "winged" center assembly or standard full hubcaps. Yours sound like a 1967 application with "beauty rings" and center caps.............
    • Michael J.
      • January 27, 2009
      • 7140
      Re: 66 wheels
      411656-583x437.jpegThe wheels would be black steel, and this is what the hubcaps for a '66 look like.......
      • David L.
        • July 31, 1980
        • 3310
        Re: 66 wheels
        The 1965-1966 Corvette wheels (GM # 3869156) are 15" X 5 1/2" and have no stampings oil the face of the wheel except maybe "GM", I forget. The stampings are on the inside of the rim that you can not see with a tire on the wheel. Attached is a drawing showing the cross section with with width measurement and offset.
        The 3869156 wheels sold "over the counter" in the late 1970's and 1980's had stamping by the valve hole as well as on the inside of the rim.
        Dave
        • John B.
          • April 20, 2021
          • 111
          Re: 66 wheels
          Thanks Stephen, David and Michael for your help. The wheels that are on my car have been on it from when my Dad bought it in 1969. I guess the original owner put these on. This is why i have been searching hard for the build sheet/window sticker. I sure wish i could find it.
          • Michael J.
            • January 27, 2009
            • 7140
            Re: 66 wheels
            If you have the original jacking instructions sheet under the package board that covers the tool area behind the seats, it will be different for steel wheels with hubcaps vs. quick take-off wheels.
            • John B.
              • April 20, 2021
              • 111
              Re: 66 wheels
              Michael, Thanks i will take a look.
              • Philip A.
                • February 26, 2008
                • 329
                Re: 66 wheels
                I don't believe 1966 had build (broadcast) sheets, that was 1967 and up.
                • Jack M.
                  • March 1, 1991
                  • 1168
                  Re: 66 wheels
                  Although the 'Tank Sticker' was ADDED in 1967, there were additional documents in the batch of printouts.
                  In this case (from an old Restorer article) this was similar to the 1966 'Corvette Order 7' (typically in the top/right corner).
                  But the Corvette plant ran out of forms... so they went over to the TRUCK side of the factory, and borrowed some of their blank forms.
                  Not very common to find the 'Corvette Order 7' (or similar), but some people have posted examples of these docs in the past.
                  • Pancho T.
                    • July 31, 1993
                    • 238
                    Re: 66 wheels
                    Hello all,
                    Mike
                    What you are describing "silver steel wheels with the rings and center caps" are rally wheels. Rally wheels did not come out until 1967 application
                    • Russ S.
                      • April 30, 1982
                      • 2162
                      Re: 66 wheels
                      What are the stampings around the valve stem?
                      Hello all,
                      Mike
                      • Mark F.
                        • July 31, 1998
                        • 1563
                        Re: 66 wheels
                        In addition to what Russ has asked, where are you seeing the "GM" and "KH" stamps?
                        thx,
                        Mark
                        • John B.
                          • April 20, 2021
                          • 111
                          Re: 66 wheels
                          Here is a picture.
                          • Russ S.
                            • April 30, 1982
                            • 2162
                            Re: 66 wheels
                            There's your answer. DC wheels are 67 rally wheels.
                            Here is a picture.
                            • Tom D.
                              • September 30, 1981
                              • 2136
                              Re: 66 wheels
                              This relates to the discussion of documents in this thread. Above is one of the sheets created for 1966 Corvette number 2999 in mid-October of '65. The delivery date on this Corvette was on 10/30/65 and it went to a GM employee who is no longer with us. I went to the selling dealer many years ago and was lucky to find this in their files. The "files" were actually cardboard boxes (one per year) in the attic above the showroom. They let me go up and look. ...Wish I had the sense to look for other Corvettes, as this GM employee bought a Corvette each year, and had each delivered to this small dealer. Yes, they are still in business, as "Hartway Chevrolet" now.
                              https://MichiganNCRS.org
                              Michigan Chapter
                              Tom Dingman
