'54 C-1 ride height - NCRS Discussion Boards
'54 C-1 ride height
  • Brian W.
    • September 30, 1990
    • 216
    '54 C-1 ride height
    My car sits high in the front end. I'm assuming I have after-market or the wrong coil springs. I noticed in Corvette Central's catalog they sell '53-'62 standard front springs. Will these springs correct my ride height, has anyone tried them? If so how does the car sit? Thanks.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17768
    Re: '54 C-1 ride height
    Brian,
    Researched this for 56-7 and hopefully the same for your '54. Measurement from ground to the center of the headlights is 26 1/2 inches. The rear wheel well opening at the center, is also 26 1/2 inches from the ground.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • David H.
      • June 30, 2001
      • 1544
      Originally posted by Brian Waller (18255)
      My car sits high in the front end. ...
      Brian
      Where are you measuring? What is this height?
      Does rear sit too high as well?
      Dave
      • Brian W.
        • 216
        Thanks Guys:
        The measurement from the wheel arc to the floor is 28 1/2" rear and 30" front. The back doesn't look bad but the front looks high. I also checked and the rear springs are original to the car.
        • Tony R.
          • April 19, 2017
          • 201
          Photo may help as well.
          • Tony R.
            • April 19, 2017
            • 201
            I do not have measurements, but this is a photo of ours taken in the early eighties…when it was only thirty years old. It is on 6.70-15 tires.
            • Brian W.
              • 216
              Tony
              Great picture that's exactly the stance I'm looking for. If you notice in my picture the front end looks high. I would like to try the reproduction springs if it will lower the front end. Has anyone had experience with the reproductions and if so how does it look?20220206_081937.jpg
              • Gary C.
                Administrator
                • October 1, 1982
                • 17768
                Brian,
                Have you check to make sure the front coil springs are installed correctly? There's a ridge that the coil leading edge to butt up to. If a coil leading edge is installed on top, it'll raise the front end.
                Also, your car in the photo appears to sit a little low in the rear.
                Gary
                NCRS Texas Chapter
                • Brian W.
                  • 216
                  Gary
                  Springs are installed correctly. When I measure the coils they are 5/8" thick. It seems a little excessive.
                  Brian
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17768
                    Brian,
                    As I understand it, the 53-8 front coil springs are all essentially the same. The '56-7 coil springs have 10 coils and are .55 inch diameter.
                    56-7 RPO 684 front coils springs are; .636 inch diameter with 8 coils.
                    Removed - Blueprint was for the 1956 SR coil springs.
                    Also found this info from the 1961 P&A - 1953-59 Corvette front coil spring - wire diameter .55 inch, 13 3/4 free height
                    Gary
                    NCRS Texas Chapter
