1966 Muffler Black Out - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7046
    #61
    • Thomas C.
      • April 30, 2022
      • 35
      #62
      Re: 1966 Muffler Black Out
      I took on the challenge with high heat paint, a microfiber wax applicator, sponge paint brush and detailed brush. Here's the before and after trying to create a haphazard "mitt/mop" look.
      • James G.
        • August 22, 2018
        • 800
        #63
        IT could have been an air over type sprayer, which works like a pump up sprayer, just a wand which emits a solid stream or fan, you can limit the amount and projection from a hand held wand by a constant air pressure over the "pot" a few pounds a narrow fan orifice and there would be no overspray, but would be an excess to run.
        They used a hose supplied air over or perhaps a diaphram pump to supply the bedding compound for installing the fixed glass if not mistaken, something similar would work exceptionally well.
        James A Groome
        1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
        1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
        My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
        Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
        • Gary B.
          • February 1, 1997
          • 7046
          #64
          James,
          We have multiple photos showing someone using a sprayer, but, to the best of my knowledge, no photos ever of someone using a mitt. Yet the mitt idea refuses to die.
          Gary
          • Tony S.
            NCRS Vice President, Director Region VII & 10
            • April 30, 1981
            • 989
            #65
            Originally posted by Robert Peckham (66450)
            Would there be a deduction on judging the exhaust if blackout was not applied
            my car in question is a 66
            thanks Bob Peckham
            Yes, if the national 66 chassis judges are judging your car.
            Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
            Original member of the Kansas City Chapter, est'd 07/11/1982.
            Member: 1965 and 1966 National Judging Teams
            Judging Chairman--Kansas City Chapter.
            Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
            • Alan D.
              • January 1, 2005
              • 2046
              #66
              And yes even a novice judge like would me would!
              • Michael J.
                • January 27, 2009
                • 7145
                #67
                Yes indeed.
                • Don L.
                  • August 31, 2005
                  • 1005
                  #68
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Don H.
                    Moderator
                    • June 16, 2009
                    • 2268
                    #69
                    Don
                    I'm certain Tony and Gene would have liked that, had they been there judging frames at Greenville.
                    • Gary B.
                      • February 1, 1997
                      • 7046
                      #70
                      Don,
                      Without getting into the question of whether a mitt or mop was ever used, I think your summary is excellent. The only comment I would add is that a meticulously neat appearance of the blackout was a goal of the production line worker.
                      Gary
                      • Gary B.
                        • February 1, 1997
                        • 7046
                        #71
                        Originally posted by Don Lowe (44382)
                        Closing this out, I thought I’d share how the blackout I used, based on the valuable input I received through this thread, faired at the recent Greenville Regional meet.
                        I purposely sprayed one side a bit more than the other, trying to replicate some of what my research showed. Different areas of application make sense when (assUming) two operators were applying blackout to their respective sides. This seems to be confirmed in post #16. Anyway, have a look at these pics. This blackout was accepted by senior level judges without note or deduction.
                        Hope this helps!
                        Don,
                        I like it!
                        Did you clean the mufflers with anything like acetone or lacquer thinner before spraying them?
                        And what brand and type of paint did you use?
                        Gary
                        • Don L.
                          • August 31, 2005
                          • 1005
                          #72
                          Originally posted by Gary Beaupre (28818)
                          Don,
                          I like it!
                          Gary
                          I did prepare the mufflers by wiping them down SEVERAL times with lacquer thinner and then once with DuPont paint prep. I used VHT paint for the blackout.
                          Thanks again to all that helped on this project. Much appreciated!!!!
                          Don Lowe
                          NCRS #44382
                          Carolinas Chapter
                          • Gary B.
                            • February 1, 1997
                            • 7046
                            #73
                            Do you have a item # for the VHT? Flat sheen, I presume?
                            Gary
                            • Don L.
                              • August 31, 2005
                              • 1005
                              #74
                              Gary
                              Yes, flat finish. SP 102
                              Don Lowe
                              NCRS #44382
                              Carolinas Chapter
                              • John D.
                                • June 30, 1991
                                • 875
                                #75
                                I remember reading somewhere the 63 pilot line blackout pics were not typical of production as some of those cars sat in the booth and the 'more is better' theory kicked in.
