Headlight inner cup - NCRS Discussion Boards
Headlight inner cup
  • Carmelo P.
    • May 9, 2016
    • 54
    Headlight inner cup
    Installing new bulbs, found 1 round outer headlight cup.
    Both outers have #2 and OO
    on the tabs. Which shape is correct for a mid -February 1967
    C2
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: Headlight inner cup
    Carmelo, Your outer with round hole is likely a replacement, but functional if it houses the bulb properly.
    These from a late March '67. All squared hole.
    Outers 2 OO
    Inners 1 98 (edited)
    Pass Side
    Driver Side
    Outers(Low Beam) 2 OO
    Inners(High Beam) 1 98
    Trim Rings
    • Carmelo P.
      • May 9, 2016
      • 54
      Thanks Rich, will have to find an outer
      #2-00. The others are the correct numbered cups as yours.
      • Gary B.
        • February 1, 1997
        • 7053
        • Carmelo P.
          • May 9, 2016
          • 54
          As long as we agree ,a February 67 uses the square hole.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11334
            Carmelo I think it'd be safe to say.... yes.
            Gary, Good catch. Zooming closer also looks like the smaller top circle of the 8 is a telltale too.
            Rich
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11334
              A little more research..... This also helps confirm you want the square hole cups.
              Interesting that the 1967 AIM only shows the assembly which includes the lamp, cup, ring and screws.
              5955492 Inner
              5955493 Outer
              The individual parts are not identified. I checked some of my parts books and none there either. Seems odd back in the day one couldn't buy just the cups over the counter.
              It appears Zip Corvette sells the individual cups but not original configuration. They use A and B. EG HERE and HERE
              Corvette Central has this quoted in their description of the 4 piece 66L-67 442131 set.... HERE
              Correct reproduction set of 4 steel, gold-zinc plated 66L-67 headlamp bulb mounting cups. Mounts behind the headlight bulb. This version with the square center opening was used in late 1966 and 1967 These cups have the correct markings on the mounting tabs. The inners are stamped with a #1 and #98, the outers are stamped #2 and #00. 63L-66E with the round center hole use CC part #442102.
              442102 is the round center, 63L-66E (??) HERE
              Correct reproduction set of 4 steel, gold-zinc plated, 63L-66E headlamp bulb mounting cups. Mounts behind the headlight bulb. This version with the round center opening was used late 1963 to mid-1966. These cups have the correct markings on the mounting tabs. The inners are stamped with a #1 and #98, the outers are stamped #2 and #00. 66L-67 with the square center hole use CC part #442131
              I'm uncertain about their gold-zinc finish as most I've ever seen were plain zinc.
              Rich
