1963 Coil Spring Ride Height for A/C vs Standard - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 431
    Does anyone have data on ride height and/or quality of the 3833319 springs for A/C C60 cars vs the 3832684 standard springs? # of coils is 7 for both I believe. I replaced the Z06 springs with what I believe were the 3833319 springs (they had the remainders of the white tags but part# was not distinguishable). It is not an A/C car.
    Fred
  • Harry S.
    • July 31, 2002
    • 5295
    Re: 1963 Coil Spring Ride Height for A/C vs Standard
    Fred, My July 63 with A/C has springs 3832684 installed in the front. As long as I've been looking at 63, I've never seen a 3833319 installed on an A/C car. I know the AIM calls for one but.... I had the car flight judged at a National and the Chassis team agreed. They did not believe the 3833319 was installed on any A/C car in 63.
    The same applies to the fan. The AIM calls for a larger diameter fan, but it's questionable if the were ever produced or installed in a 63 A/C car.
    So, I can't help you on ride height.
    • Frederick H.
      • August 31, 1983
      • 431
      Thanks Harry - too bad I can't see any numbers on the tag. I will measure ride height once I get the hood back on. I currently have 205/75 radials on it so I may have to take that into account as well.
      THanks.
      • David B.
        • March 1, 1980
        • 689
        3832684 free height 15.147 Normal load 1340 lbs. Bar thickness .552 Assembly Plant EB
        3833319 free height 15.397 Normal load 1405 lbs. Bar thickness .552 Assembly Plane EC
        • Frederick H.
          • August 31, 1983
          • 431
          Excellent - thank you David.
