69 L68 AC Hose supplier - NCRS Discussion Boards
  • Grahame M.
    • November 7, 2011
    • 225
    Hi all,
    I have just fitted new C hoses purchased form a supplier in the US that do not even go close to fitting my car. The kinks and bends in the hoses, when fitted, could lead to a major problem in the future.
    The main problem hose is the one from the muffler to the front of the car, it won't fit under the guard/bonnet rail without some real manipulation and is not able to be cut to size. The one that goes under the guard to beneath the AC box can be cut and U shaped end reattached.
    Can someone please suggest a supplier that you have used that produces the correct part for my car (Not Paragon)?
    Many thanks again for all your help over the past few years, it has been invaluable for a very remote Corvette owner in Oz.
    Grahame
    69 427 Tri-Power 4 Speed
    Black on Black
  • Grahame M.
    • November 7, 2011
    • 225
    Re: 69 L68 AC Hose supplier
    Sorry, should have added a few pics, please see attached.
    1969 L68 AC Hose Fitment 1.jpg1969 L68 AC Hose Fitment 2.jpg1969 L68 AC Hose Fitment 3.jpg
    Cheers
    Grahame
    Black on Black
    • Mark E.
      • April 1, 1993
      • 4557
      Grahame,
      I have the same project in process with my '70. I sourced my AC hoses and receiver/dryer from Old Air Products in Fort Worth, TX (less than an hour from my home; half a world away for you). Here's the hose and manifold for your car (same part used for my car):
      I have this part but haven't yet installed it, so I can't vouch for fitment. You might ask Paragon where they sourced your part to make sure it's not Old Air. They also have selected NOS parts like POA and expansion valves.
      Keep us updated with what your learn. How did the core support and radiator come together?
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Mark E.
        • April 1, 1993
        • 4557
        Here's the hose and manifold from Old Air. The exposed rubber on the high pressure line is 20 1/4" long. (The photo shows the line curled; I wasn't able to take a photo while holding the hose straight with the tape measure). How does this compare with yours?
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Grahame M.
          • November 7, 2011
          • 225
          Hi Mark,
          I got a similar measurement to you at 20 1/2 inches for a stretched out hose. i'm going to have to find someone to attach the U shaped pipe to the hose once i get it to the correct size. I hope they can also remove and re-attach the pressure line ends as i'll have to cut this hose by about an inch and a half to fit correctly along the passenger side inner guard.
          The liquid line fits perfectly.
          I also changed the pipes up front and i think these may also be the culprits but i didn't measure old against new, rookie mistake.
          Thanks for your help, i'll let you know how i go.
          Grahame
          Black on Black
          • Mark E.
            • April 1, 1993
            • 4557
            I trial fit the manifold hose assembly and its length is good. I'm using original tubes that pass through the core support area so you might try your originals before tearing into the hoses.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • David M.
              • September 30, 2004
              • 522
              Have you investigated Classic Auto Air Or Vintage Auto Air?
              They will cut and re-weld/re-crimp the OEM fittings onto new hoses. Or provide you with all new. They can install new desiccant in the dryer as well.
              Classic Auto Air is your source for factory air conditioning parts & AC systems for 70’s & older Ford, GM, Mopar, Porsche, Custom Street Rods & more.
              Wheels of Time specializes in classic auto air conditioning parts and kits for numerous makes and models. Call us at (888) 305-1932.
              • Grahame M.
                • November 7, 2011
                • 225
                Thanks Mark and David,
                Appreciate the feedback. I have a mobile guy coming next Tuesday who I believe can help with both hoses.
                Cheers
                Grahame
                Black on Black
