Distributor Washer - NCRS Discussion Boards
Distributor Washer
  • Jimmy G.
    • November 1, 1979
    • 977
    Distributor Washer
    Part number Washer Part Number 1951099 Group 2.364 Anyone have any specifics on this part
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: Distributor Washer
    FYI It is the felt washer not metal GM should have called it a seal.
    • James G.
      • August 22, 2018
      • 808
      If not mistaken there was an actual thin clear plastic disc over the top of the felt disc. looks like soda bottle clear plastic
      • David B.
        • March 1, 1980
        • 690
        1951099 is a Delco Remy part number. You might be able to find in one of their older catalogs.
        • Larry M.
          • January 1, 1992
          • 2701
          It is just a piece of felt, about 1/4 inch thick. Circular with a hole cut in the center for mounting. It fits OVER the plastic upper bearing cavity seal. and is saturated with 30 wt engine oil.
          I purchased mine from LICS, but Zip, CC, and others should have one. Ebay also.
          The hard part for me to get was the plastic cavity seal...........but they are still available from GM if you know where to look.
          Larry
          EDIT: https://www.ebay.com/sch/i.html?_fro...tor+felt+seals
          • Jimmy G.
            • November 1, 1979
            • 977
            What I have been doing is buying pass car distributors at flea markets for 5 bucks or so and using them for the small parts as they are the same as Corvette
