Part number Washer Part Number 1951099 Group 2.364 Anyone have any specifics on this part
Distributor Washer
Re: Distributor Washer
It is just a piece of felt, about 1/4 inch thick. Circular with a hole cut in the center for mounting. It fits OVER the plastic upper bearing cavity seal. and is saturated with 30 wt engine oil.
I purchased mine from LICS, but Zip, CC, and others should have one. Ebay also.
The hard part for me to get was the plastic cavity seal...........but they are still available from GM if you know where to look.
Larry
EDIT: https://www.ebay.com/sch/i.html?_fro...tor+felt+seals- Top
