Carb throttleplate torque - NCRS Discussion Boards
  • Keith W.
    • May 25, 2018
    • 202
    How tight should I torque the throttleplate on my Holley carb? I had to have it repaired due to a crack.
  • David H.
    • June 30, 2001
    • 1558
    Re: Carb throttleplate torque
    Keith
    If you mean base plate to manifold, then 60 to 80 inch pounds. Link to Holley site:
    Dave
    Judging Chairman Mid-Way USA (Kansas) Chapter
    • Keith W.
      • May 25, 2018
      • 202
      Dave, I meant baseplate to carb. I had to take the baseplate off for repair. I think the carb to manifold should be closer to 60 as the natural vacuum from the engine will keep the carb in place. Thanks Keith
      • James G.
        • August 22, 2018
        • 808
        The issue is not keeping it in place, vacuum leaks after the carb metering circuits will cause lean mixtures and really fight you setting the idle-(air introduced after fuel metering leans the mixture)
        REMEMBER INCH /Pounds
        The base plates with the correct drivers rear mount tab are difficult to locate. By late 71 and as far as I know all of 72 have the re-enforced version of the base plate with the "additional lump" connecting the rear throttle blade shaft boss to the rear drivers mount tab.
        Keith, I had a phone explode and I lost your contact info - send me a text.
        • David H.
          • June 30, 2001
          • 1558
          Keith
          Throttle plate to main body is 25 to 30 inch pounds. Torque values are in that link above.
          Dave
          • Keith W.
            • May 25, 2018
            • 202
            Thats what I thought. Thanks Dave. I have a torque screwdriver coming to tighten up the screws. I thought my torque wrench would not give me accurate readings.
            • Keith W.
              • May 25, 2018
              • 202
              Sent you a text message. K
