Motor oil - NCRS Discussion Boards
Motor oil
    • 15667
    Re: Motor oil
    Go to the following link, and download the oil article pdf:
    https://www.corvetteforum.com/forums...corvettes.html
    The article was originally written in 2008 when the CJ-4 category went into effect. The current CK-4 category wear test suit did not change, nor did the P limit.
    CK-4 oil is vastly superior to the engine oils available when most vintage Corvettes were new in terms of wear protection, oxidation resistance, and other parameters. Some current CK-4 have much less than the P limit because their additive package includes newer Boron-based anti-wear additives.
    So the P/Zn level is not the sole determinant of the oil's wear protection. Regardless of the additive package, all CK-4 oils have to pass the C-category wear test suite, which is a higher hurtle than the S-category wear test suite, and since both cost about the same, why buy a S-category oil and add a ZDDP additive?
    I find that Walmart usually has the best prices on motor oil. They carry both the three major CK-4 national brands and their own SuperTech house brand, which is usually less expensive, so that's what I buy.
    In ag country there are lots of house brands. As long as they have the API "donut" with CK-4 as the FIRST listed category, they are the real McCoy
    • Edward B.
      • January 1, 1988
      • 537
      Re: Motor oil
      Sticking with a brand that has a proven track record such as "Rotella," is in no way as silly as using WD-40 as a lubricant or a "rust buster," uses for which it was never intended. Advertising and spray can convenience are hard factors to overcome with common sense.
      • Michael J.
        • January 27, 2009
        • 7119
        #18
        Re: Motor oil
        I use VR-1 in all my C2s, and have for years, I am very happy with it.
        • Bernie B.
          Infrequent User
          • August 25, 2018
          • 21
          #19
          Re: Motor oil
          Thanks Michael on your reply regarding VR-1. All the posts both past and present have been very informative. Thanks Bernie
          • William F.
            • June 9, 2009
            • 1363
            #20
            Re: Motor oil
            Racing oil is designed for racing and as such may not have characterists that you need for a street driven machine, such as long lasting corrosion protection or maybe not as long a life as the C rated oils. The long term corrosion protection affored by C rated oils is one of its most important qualities for our mainly only occassionaly driven Corvettes.
            • Michael J.
              • January 27, 2009
              • 7119
              #21
              Re: Motor oil
              Valvoline VR-1 is CD rated too, CF is now an obsolete category.........vr1-racing-oil.pdf
