67 Squeak - NCRS Discussion Boards
67 Squeak
  • Enzo C.
    • January 12, 2012
    • 536
    Re: 67 Squeak
    Hello Doug, yes will definatley have to check that in the spring time , thanks
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
      • 6956
      • Michael M.
        • February 1, 1993
        • 605
        #18
        Re: 67 Squeak
        An easy check would be to inspect all the rubber bushings in the rear.
        • Enzo C.
          • January 12, 2012
          • 536
          #19
          Re: 67 Squeak
          The noise is in the back not in the cluster or engine bay
          Enzo Colosimo
          ENZ-Z06/67
          • Gerard F.
            • June 30, 2004
            • 3806
            #20
            Re: 67 Squeak
            Enzo,
            If the squeak changes with speed or braking or seems to come from one side, check your rear wheel bearings.
            Here's what happened to me when I ignored a slight noise from the rear of my 67:
            Rear wheel bearing failure
            Jerry Fuccillo
            • Mark M.
              • October 21, 2008
              • 343
              #21
              Re: 67 Squeak
              Hello Enzo, Can you hear the squeak if you bounce the rear of the car up and down by hand on the bumpers? Or does the sound have a frequency with speed of the car as to a spinning part?
              • Enzo C.
                • January 12, 2012
                • 536
                #22
                Enzo Colosimo
                ENZ-Z06/67
                • Enzo C.
                  • January 12, 2012
                  • 536
                  #23
                  Enzo Colosimo
                  ENZ-Z06/67
                  • Mark M.
                    • October 21, 2008
                    • 343
                    #24
                    Re: 67 Squeak
                    OK then, would you say it makes a speeding up and slowing down sound as car does? Does it only do it at higher speeds?
                    • Enzo C.
                      • January 12, 2012
                      • 536
                      #25
                      Enzo Colosimo
                      ENZ-Z06/67
                      • Mark M.
                        • October 21, 2008
                        • 343
                        #26
                        Re: 67 Squeak
                        At first guess, it may be part of the rotating assemblies. Other members here mentioned some already. The rotors, u-joints,wheel bearings. As Doug mentioned, I too would start with the rotors which may not be spinning true. Hard to say without hearing.
                        • John P.
                          • January 1, 2006
                          • 163
                          #27
                          Re: 67 Squeak
                          Hello Enzo, Years ago when I restored my 67, I had a squeak coming from the right rear when the wheels rotated. It turned out to be a stick -on wheel weight that was installed on the inside of the right rear wheel contacting the caliper when rotating. My car has the aluminum bolt on wheels that required this type of weight. Check for any interference with the inside of your wheels with all brake and suspension components. Have someone stand beside your car while driving slowly by to help pin down the location of the squeak. Good luck!
                          • Doug M.
                            • January 1, 1991
                            • 68
                            #28
                            Re: 67 Squeak
                            Enzo,momentarily, partially engage the parking brakes while driving to eliminate them as a source
                            Doug
                            • Enzo C.
                              • January 12, 2012
                              • 536
                              #29
                              Enzo Colosimo
                              ENZ-Z06/67
