67 Squeak - NCRS Discussion Boards
67 Squeak
  • Enzo C.
    • January 12, 2012
    • 534
    67 Squeak
    I wanted to ask if anyone is experiencing a squeak at the back of a 67
    car is restored and I checked all bolts with torque wrench
    maybe some comments or recommendations would be appreciated
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Jaime G.
    • April 1, 1988
    • 480
    Re: 67 Squeak
    Enzo, I had a squeak in the back (driver side) of my restored 65 roadster.
    After many tries, I added a shim to the mounting bolt behind the driver position
    on the body and it leveled the door which eliminated the squeak. Its a bit
    of work, but after two years, I got rid of the annoyance.'
    • Domenic T.
      • January 29, 2010
      • 2452
      Re: 67 Squeak
      Could be the spring. they have rubber between liefs but a possibility!
      Dom
      • Danny P.
        • June 30, 2002
        • 344
        Re: 67 Squeak
        May have a Ujoint squeak Enzo, hard to say without hearing it
        • Keith B.
          • September 15, 2014
          • 1588
          Re: 67 Squeak
          If a coupe check all the plastic window trim and make sure the screws are tight.
          • Gary J.
            • April 1, 1980
            • 1244
            Re: 67 Squeak
            Be careful tightening the plastic trim on a coupe, it could crack.
            • Keith B.
              • 1588
              Re: 67 Squeak
              Or the screw holes will be stripped
              • Mark L.
                • 561
                Re: 67 Squeak
                I would vote for Jamie's suggestion. I had a similar problem due to at least one body mount not having any shims.
                • Enzo C.
                  • January 12, 2012
                  • 534
                  Re: 67 Squeak
                  Hello I appreciate the replies
                  I forgot to mention that I have a coupe
                  Enzo Colosimo
                  ENZ-Z06/67
                  • Alexander D.
                    • July 9, 2015
                    • 113
                    Re: 67 Squeak
                    Hi Enzo,
                    Carefully check the stainless steel moldings all around the back window. Mine developed a squeak that turned out to be caused by one of the molding clips breaking, allowing the molding to pop up (out) a bit and rub against the body when going over any kind of bump. Push down on the moldings all around the window to ensure these are held tight and not causing a squeak.
                    Let us know what you find.
                    • John F.
                      • March 23, 2008
                      • 2413
                      Re: 67 Squeak
                      Also check the clearance on your rear exhaust extensions.
                      • Enzo C.
                        • January 12, 2012
                        • 534
                        Re: 67 Squeak
                        Yes sir checked the whole exhaust system front to back and all clear
                        Enzo Colosimo
                        ENZ-Z06/67
                        • Enzo C.
                          • January 12, 2012
                          • 534
                          Re: 67 Squeak
                          The squeak is when you drive not over bumps
                          Enzo Colosimo
                          ENZ-Z06/67
                          • Doug M.
                            • January 1, 1991
                            • 68
                            Re: 67 Squeak
                            Enzo,
                            Slight brake pad movement caused by a warped brake rotor
                            Doug
                            • Jimmy G.
                              • November 1, 1979
                              • 977
                              Re: 67 Squeak
                              In my case it was repo spring liners -- too hard I think. After they wore it it went away --- at least in warmer weather. Still squeaks some in colder temps.
