63 FI Idler pulley - NCRS Discussion Boards
63 FI Idler pulley
  • Todd L.
    • November 25, 2020
    • 285
    Re: 63 FI Idler pulley
    Yes Sir, I will check and let you know.
      • December 1, 2005
      • 185
      Todd,
      I recently completed restoration of my '65 Fuelie and had to deal with the idler pulley too. I decided to get a new one from Paragon. It arrived and I compared it with my original unit. The reinforcement recess that is stamped into the single bolt anchor leg was just opposite that on my original. So, I sent it back and restored my original using a new bearing that I found on Ebay. Turned out good, no issues in judging. Not sure if it is the same for a '63.
      • Todd L.
        • November 25, 2020
        • 285
        #18
        Thanks for the advice Terry, I am trying to restore absolutely every piece of this car without buying reproductions, for the very reason you mentioned. I appreciate your input.
        Todd
        • Todd L.
          • November 25, 2020
          • 285
          #19
          After sandblasting the bracket, I see there is a tiny hole drilled in the flange. Is this factory, and if so, what is it for? If not, I assume someone drilled it in there for something?? Any help would be appreciated.
          Todd
          • Bob W.
            • December 1, 1977
            • 802
            #20
            Todd, Have you received the replacement bearing bearing from Zip?
            • Todd L.
              • November 25, 2020
              • 285
              #21
              Hey Bob,
              Yes, I have received it and am taking everything to a shop that has a press so they can install this properly for me.
              Todd
              • Bob W.
                • December 1, 1977
                • 802
                #22
                Todd, Thanks for the reply. Were their any numbers on the bearing? Also keep us posted how it works out.
                Thanks Bob
                • Todd L.
                  • November 25, 2020
                  • 285
                  #23
                  No numbers that I could find.
                  • Bob W.
                    • December 1, 1977
                    • 802
                    #24
                    Ok ,thanks again Bob
                    • Alan D.
                      • January 1, 2005
                      • 2038
                      #25
                      Tod, NO hole on my original Mar64 FI car. Alan
                      • Todd L.
                        • November 25, 2020
                        • 285
                        #26
                        Thank you Sir!
